20 Most Recent
RCA F36685 36" TV Questions & Answers
I have an RCA 36"
Hi, in most of these RCA TV, we found a common problem with that strange sound. You need electronics skills to solve this problem. The sound coming from the TV ( back cover), caused by a faulty transformer T14401 location number, part number 241319, also a transistor horizontal output is shorted need be replaced. location Q14401 part number, part number 237470. This is a difficult and you may have to find a tv shop and ask for a previous estimate of money. I hope all this clear in my explanation and if you have further questions, I'll be here to help.
My rca sdtv model 27v414t, the picture won't fit
You are describing normal operation. I have a Samsung with the 4:3 screen aspect ratio and deal with the same issues. With a program that is broadcast as HD I have the "letter box" pic. since this is needed to amintain the 16:9 ratio it is formatted in. Some programs come up as only filling part of the screen & at times I find the zoom mode less objectional to view. Even if you have a wide screen set you still deal with programs that are not in the 16:9 format. Perhaps eventually all programming will be in a consistent format, but for now we just have to put up with it. The good news is that your TV is not defective.
Input selector Menu says on blocking the shown picture
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If not a part the unit will need a firmware upgrade. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher. A firmware upgrade shouldn't be more than $200 unless the manufacturer charges a lot for the software.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
RCA p49622 will not power on at all
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced.
The question will be, is the part still available? Before paying a TV
repair person $75+ to diagnose the problem, ask yourself if you're
willing to pay $150 minimum to fix this particular set. Also keep in
mind that most TVs that old have a very limited number of replacement
parts still available. Normally it will cost at least $75 to have the
set looked at by a repair shop (diagnostics). If the part needed to
complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
RCA F36685 wont power on
Probable bad flyback transformer....verify service number
last three digits YX2....Part # is 244247.............................T.
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
Tv does nothing
ahhh the noise maker comes to life again .. Ok my friend this is a common problem with this set If your lucky?? If you know anything about trouble shooting tvs then this is what ya got.. Try first to measure the Horizontal output transistor. It will meaqsure a few ohms between the base and emmitter. But the base and collector should measure about 450 to 550 olms on the diode settings onm the metter.if it measures shorted you need to replace the flyback tranformer along with the Horz output transistor. Now if the HOT( thats horiz output transistor)is not shorted then theres a little coil in the horizontal drive thats causing problems as you need to take out the coil from the PCB and scrape off the ends and reinstalkl it. also the horizontal driver tranformer as well as the resistor that feeds the transformer could be bad and thast is a 3200 ohm at three watts. if ya dont have a clue what I just said the sets gonna cost ya ariynd 200 to 300 to fix .. Is it worth it to ya>?????lol Good luck
Will not turn on?
the lightining battery is not working very well.
You should exchange it, so the TV power could get to the Tv and let it Work.
Rca 36" F36685
YX2 = part # 244247..................................................T.
Thermistor
Part # 207768 .......................................................T.
RCA36 INCH MODEL #F36685
Bad flyback transformer....please provide service number from
back of set for more info..........................T.
RCA F36689 with Chassis CTC197CR
HI, MY MAME IS vICTOR FROM COSTA RICA.
YOU NEED A TV TECHNICIAN BECAUSE YOU HAVE SOME PROBLEMS WITH THE ELECTRONICS CIRCUITOS INCE.
I HAVE THE SAME TV, AND I FIXED 2 MONTH AGO, THE PROBLEM MAY BE IS THE FLYBACK, THE PUSH BUTTON PANEL. DO NOT USE AEROSOL, BECAUSE CAUSE MORE PROBLEMS INCIDE
