20 Most Recent RCA F36669 36" TV Questions & Answers
My universal remote can't be used to turn speakers back on my f36669 tv
Not a surprise as Universals even if they program will be missing key and needed features.
11/1/2012 3:46:57 PM • RCA F36669 36"... • Answered on Nov 01, 2012
0answers
2answers
Rca f36669. blows fuses. power supply shows burn
7/25/2011 9:54:39 AM • RCA F36669 36"... • Answered on Jul 25, 2011
Cannot turn tv on and
Well, this is most obviously an "error code" built in for the purpose of debugging, perhaps if you inform me as to how many beeps it does? how long after powering on it takes to beep? Does the power light come on? Is the power light the standard (normal) color it always is? Do you see anything on the screen? And does the remote power it on? These are all things that could help me in resolving this issue for you Regards, Dracconus
1/8/2011 6:02:35 AM • RCA F36669 36"... • Answered on Jan 08, 2011
I have an RCA F36669 tv that doesn't stay on.
look to see if the wire is in tv. unplug there 28000 volts there and it hurt use a long handel sew drive to find out unplug tv
7/9/2010 8:54:22 AM • RCA F36669 36"... • Answered on Jul 09, 2010
Water leaked inside , no power, is there a reset button?
First of all I must how much water leaked inside and was it actually water or something else?
Most of the time if the set was off and you left it off for a couple of days the water would simply evaporate and the set would continue to work.
I have seen other things spilled into sets, like plant water with fertilizer or etc. that cause corrosion and will cause the printed wires, the PC board traces, to actually corrode and the set will fail. If that is the case then wait until it's completely dry and take it to a shop. If it's just a few corroded traces it will be easy to fix... if not then it might be a major repair depending on if something was actually damaged or not.
Zashiban
6/28/2010 12:42:03 AM • RCA F36669 36"... • Answered on Jun 28, 2010
My rca model f36669 makes a popping sound and cuts
That's hi voltage arcing. Dangerous condition were a component has broken down and is arcing causing the power supply to 'crowbar' or go into over current protection mode. Call a TV repair pro for an estimate to see if you want to keep the set.
4/26/2010 7:31:05 PM • RCA F36669 36"... • Answered on Apr 26, 2010
Can't get universal remote to work
is your type of tv listed among the machines it can work with? if so make shure you input the correct code.
4/7/2010 6:42:35 AM • RCA F36669 36"... • Answered on Apr 07, 2010
Where can I get the part?
Take your board to the local TV repair shop. They will be able to replace the individual micro switches and save you a small fortune replacing the whole control board.
4/13/2008 5:23:06 PM • RCA F36669 36"... • Answered on Apr 13, 2008
Need new panel
the control panel,possible a bad component on it like a stuck switch ,remote p/u sensor
3/28/2008 11:38:55 PM • RCA F36669 36"... • Answered on Mar 28, 2008
RCA CTC203
with your new flyback transformer ther should have had a resistor and cap in the kit.if you look at the fly back from the rear ,on the right side very close to the transformer.and on the other side 3 resistors one has changed value about 38k-ohm.
3/28/2008 11:36:11 PM • RCA F36669 36"... • Answered on Mar 28, 2008
No life
sounds like the sat receiver not the tv.
3/23/2008 11:17:25 PM • RCA F36669 36"... • Answered on Mar 23, 2008
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
RCA F36669 36" TV Logo
Popular Tags
14 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
universal remote 39 t used turn
  • Televison & Video
