Hi spikehair200,
Make sure that you replaced the fuse with exact ratings. Low ampere ratings will not handle current as what the original fuse installed. If still fuse keeps blowing after replacing with the same rating, this is an indication that you have a short on the power supply section. It can't be fixed by replacing the fuse alone. Short usually near the AC line where parts like the following are present.
This is the common parts that might be shorted and made the fuse blew. You may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don
3 questions posted
2,410 Questions
1,124 Questions
809 Questions
789 Questions
510 Questions
