20 Most Recent
Northgate (STCAX30X) PC Desktop Questions & Answers
Would a Northgate computer bought in 2001 or 2002
I'm not familiar with you machine, but if you have usb ports they are probably on the back of the machine (tower). Check there. If you don't have any, you can pick up a usb 2.0 card pretty inexpensively on eBay or I think at Best Buy and simply open the case and plug it into one of your empty card slots. Software typically comes with the card, or, if you have plug and play, the machine will find the card and set it up.
Good luck.
10/5/2009 6:19:12 PM •
Northgate...
Answered
on Oct 05, 2009
I try to put 2 ram chips (matching) into my
If you are getting the problem in the RAM slot then try both the RAM 1 by 1 in that slot only. And start your pc.
Otherwise there is a fault in your motherboard and you need to go the service center.
3/12/2009 7:41:01 AM •
Northgate...
Answered
on Mar 12, 2009
Hard Drive Data Recovery
you can download mrecoverxl and try it your data from both the partitions will come in one partition, and your computer will start without instaliing your os too
11/7/2008 6:50:01 PM •
Northgate...
Answered
on Nov 07, 2008
Northgate I-7
the best thing for you to do is take the side off your desktop pc and look at the motherboard make and serial number and also look at northbridge and southbridge chipsets (the square looking chips) and make a note of tyhe make also.
When you have the details either post back or search yourself, as Northgate are only a pc builder and not a manufacturer.
8/14/2007 10:14:04 AM •
Northgate...
Answered
on Aug 14, 2007
Power supply
Hiya Its pointless changing power supplies and farting around with them They are so cheap in todays world Buy a new one with online support Click this link Power supplies start from £4.00
http://tinyurl.com/yqkmo9
If you like this site Tell all your friends and give them this link.
8/4/2007 11:58:02 PM •
Northgate...
Answered
on Aug 04, 2007
Casx02017r
Try changing the CMOS battery, and see if the problems go away.
8/7/2014 4:46:07 AM •
Northgate...
Answered
on Aug 07, 2014
Sparks from back of computer
Please don't turn it back on. Unplug your computer from the wall and examine the wall socket for blackened or burned sections. It is likely that dust has caused a short in your computer. Sadly, most times this means that you are going to need a new computer or at the very least, some new parts. Take it to a reputable computer repair shop near you and have them test the power supply and other components to see what is salvageable of your computer. With any luck, your hard drive contents MAY have survived but there is no guarantee.
3/27/2014 12:42:34 AM •
Northgate...
Answered
on Mar 27, 2014
40drhol can I erase and reuse a good hardrive, I have the recovery cd and the otherboard cd. hanks Rich
"40drhol"? If you are re-installing the OS, when you re-install it will ask if you want to format. If the HDD is not the Primary HDD in your computer. a spare HDD, If the HDD is compatible with your computer interface you can install as a slave/second/primary, depending on the interface/pin outs, or load a different OS on it if you wish and have a Dual-Boot. If it's a second drive in your computer, Open Start Menu, Computer, Select the HDD, just right click and format ,select File System.
2/15/2013 12:16:49 PM •
Northgate...
Answered
on Feb 15, 2013
Connecting hp photo smart 7350 printer to northgate computer
Hello,You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer. After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually). I hope this helps.If you need more info, please let me know.Carlo
1/23/2013 5:13:52 AM •
Northgate...
Answered
on Jan 23, 2013
No Sound on Nothgage I-1
You may have to use the XP drivers . there may not be drivers developed yet for the Windows 7.
The manufacturer is the one who supplies compatible drivers to run with the operating system.
6/21/2011 11:20:15 PM •
Northgate...
Answered
on Jun 21, 2011
I need the sound drivers
Go to the control panel and find the system folder then find the device manager then find your sound card and you can load the driver from there. Also make sure your sound is not muted.
4/20/2011 2:07:11 AM •
Northgate...
Answered
on Apr 20, 2011
I have a northgate protek
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
3/27/2011 5:07:35 AM •
Northgate...
Answered
on Mar 27, 2011
Have no sound.
Does this problem came all of a sudden? Do you hear sounds before? Check the icon with the speaker (or something like this) at the lower right end of the taskbar. Is it marked as forbidden? Click on it and enable sounds.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
9/9/2010 1:35:06 PM •
Northgate...
Answered
on Sep 09, 2010
