20 Most Recent
RCA F27645 27" TV Questions & Answers
The cable jack on the back of tv, you know the one
The input on the tuner needs to be replaced. It will have to be unsoldered from the outside of the tuner and there is a lead inside of the tuner that has to be unsoldered to get the old one off. You will then have to solder the new one back into those places. The input is only a buck or two. An old trick that some people do, is get a small piece of aluminum foil and stick it into the hole, and then reconnect the cable. Just make sure the foil is all the way in, and not touching the metal on the outside of the input. That will help a lot of times.
RCA 27" TV
typical problem with an older set. sounds like the crts starting to fade as manufactureres Im thinking build into a set faults that they know will happen after a certain time frame and most do this is why there are so many reoccouring falures in a tv sets life. this is simply my thoughts on this subject!! You could have your local tv guy shoot the tube (not with a gun!!) with a crt rejuvenator to maybe clean off the grids of the tube. sometimes this will help BUT its a risk also Sometimes it will ruin the picture tube also. I have a set that I rejuvenated the tube 4 years ago as it looked like crap but to this date s its stil looking good as it did when new!
RCA 27" TV F25432
You apparently have a high voltage arc.
Possibly the anode lead to your picture tube.
Also the flyback transformer could be arcing.
If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock.
Be careful !!!
Stargazer
TV blinks intermittingly
No you didnt answer the most important questions> When the tv"blinks" does the sound go on and off with the picture? Or does the picture go out to a black screen or a grey screen? or does the whole set seem like its shutting off and on again? or does ir seem like the tvs trying to tune in a channel but keeps going past the right frquency? Answer these questions and we can get somewhere.
How to replace cable jack
Are you saying the input for the rf dosent work?? Have you tryed the video input?? Do you get any picture on the tv at all, i.e. a blank screen, lines white screen, ect, ect. Cable jack dosent work???? Ok I think I know what you mean, but PLEASE in the future dont make me quess ?? Give as much info as possible if you want help?? Pleasse?? It sounds like the typicale RCA tuner problem as RCA's have been having this problem since they went over to canada ( and no insult to the kanooks LOL) No really since RCA was bought by Thompson corp they have been having problems with their on board tuners and the tuner sheilds. Almost every set sold in the past have had this problem and to this date. Im not sure who they paid off not to have a class action law suit against them?? Its a commonm problem that will cost you abot 75 to 150.00 Bucks to have fixed once and for all. .BUT IF YOUR NOT A TECH!!!!! do not attemt this repair as it will kick you in the butt as these sets as well as all tvs hold a very high voltage charge that will kill ya if you dont know where or what your doing!! Good Luck
Every channel is static, no sound
Unplug the tv set for 30 seconds, plug back in and turn set on.
if this does not return your audio you need and you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint. All can be replaced at a local electronic or hardware store and they're easy to replace
good luck
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
What is the code for remote control for RCA model# RT 1971-AC
Better idea
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com
https://www.amazon.com > Replacement-DETG160R-...
Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control.
US$32.99 · In stock
RCA RT1971AC Replacement Remote
Remotes.net
https://www.remotes.net > products > replacement-rem...
If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems.
US$34.90
RCA Universal Remote Codes:
- The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
- The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
- The cable box codes are: 000 and 027.
Apr 26, 2023
