20 Most Recent RCA F32648 32" TV Questions & Answers
A high pitch squeal, no pix/no sound when powered up..any thoughts
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
12/11/2015 8:44:10 AM • RCA F32648 32"... • Answered on Dec 11, 2015
Why do channels keep changing on their own every 2 seconds?
Main system control memory IC fault. Replace it. Contact any service technician.
5/1/2015 5:37:38 AM • RCA F32648 32"... • Answered on May 01, 2015
My emerson tv volume started automatically going down. my tv isnt even a year old what would cause it to that
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/10/2014 9:46:59 AM • RCA F32648 32"... • Answered on Apr 10, 2014
manual
F32648 32" TV Manual
RCA F32648 32" TVUploaded on Apr 06, 2014
TV has no picture and no sound
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
4/5/2014 4:40:53 PM • RCA F32648 32"... • Answered on Apr 05, 2014
How much money to replace the power supply in a rca tv
It will depend on the price of damaged components.
6/3/2012 3:06:09 PM • RCA F32648 32"... • Answered on Jun 03, 2012
How much does it cost to remove and replace a power supply
my friend here in guyana to replace a power supply it is VERY expensive i don,t know about your country
6/3/2012 1:43:29 AM • RCA F32648 32"... • Answered on Jun 03, 2012
Plano RCA F32648 32
What is the problem with your rCA TV? Please provide some more details.
4/28/2012 1:47:01 PM • RCA F32648 32"... • Answered on Apr 28, 2012
The remote will not control the tv, the guide plus
A suggestion for your question. First make sure your TV is synchronized with your cable company account. Then go into the Guide Plus+ and go to settings. From there you can locate audio or remote settings to manage them there. Take time to look thru the Guide Plus+ menu, where you can find where you can turn on or off your Guide Plus+ screen, Its in there.
1/2/2012 7:37:03 PM • RCA F32648 32"... • Answered on Jan 02, 2012
3answers
Tv sparked and made noise and shut off rca model f32648
Looks like the projection is fried. I'm afraid you would have to exchange for new one if you can or purchase new Tube.
11/12/2011 5:37:45 AM • RCA F32648 32"... • Answered on Nov 12, 2011
I have a rca tv model#f32648 noise from back and
Shorted horizontal output transistor. Might have to call a service technician, normal parts and labor charge $100-125.
11/12/2011 5:34:11 AM • RCA F32648 32"... • Answered on Nov 12, 2011
My tv shoot off, and
That would be a low value thermistor. Usually 2.2 ohm, can replace with a resistor but not recommended for safety reasons.
11/12/2011 5:32:35 AM • RCA F32648 32"... • Answered on Nov 12, 2011
I have rca model f3648. child turned down
Look at the back of the tv, look to the right should be an opening for an adjustment, small screw driver adjusts screen.
11/12/2011 5:29:56 AM • RCA F32648 32"... • Answered on Nov 12, 2011
Tv wont turn on red light flashes 25 times
Bad e-prom ic. Part number 24CO4 OR 24C08. Need to order by chassis number, 8 pin ic located at the front left of the board, Will be marked on the top of the ic,
11/12/2011 5:28:19 AM • RCA F32648 32"... • Answered on Nov 12, 2011
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also have you tried following things 1 - playing different dvds (dvd player ) 2 - changing different channels ( cable tv or antenna ) 3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ] contrast colour tint black level sharpness picture presets auto colur colour warmth 4 - auto channel searching ( cable tv or antenna )even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
11/8/2011 2:52:15 PM • RCA F32648 32"... • Answered on Nov 08, 2011
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
8/30/2010 10:29:35 PM • RCA F32648 32"... • Answered on Aug 30, 2010
RCA F32648 32" TV Logo
64 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
plano rca f32648 32
  • Televison & Video
