20 Most Recent RCA 20F530T 20" TV Questions & Answers
Your TV may be defective.
RCA 20F530T 20"... | Answered on Jul 20, 2017
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
RCA 20F530T 20"... | Answered on Mar 28, 2014
There are a lot of different possible issues that may cause this most likely the TV is on the wrong station. Try tuning it to 60 or 73 if this doesn't resolve the issue just reply!
Daniel Busa
DISH Network
Customer Service
RCA 20F530T 20"... | Answered on Jun 03, 2011
Hello prunefeet.
If you're certain you've connected the cables correctly, I think the part you may be missing is selecting the correct input on the TV. Switch the TV and DVD player on, then press the INPUT button on the RCA remote (supplied with the TV) slowly and repeatedly until you either get the setup/welcome screen from the Sony DVD player or you return to the TV channels again.
If you don't have the original RCA remote control or you cannot find the signal from the DVD player by pressing the INPUT button, please can you let me know the following:
1. How many jacks/plugs are there on each end of your RCA cables - 3 or 5?
2. Which remote control do you use to operate the TV?
Thanks,
BElectric
RCA 20F530T 20"... | Answered on Mar 27, 2011
Front Panel Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV's front panel. The remote still tunes to any channel. When using this as a Parental Control method, remove access to any remote
that is capable of operating the television.
1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel.
2. Press the right or left arrow to turn on (box has check mark) or off (box doesn't have check mark) front panel lock.
RCA 20F530T 20"... | Answered on Sep 22, 2010
first off are there any speakers close to the tv ?. if so move them secondly your degauss circuit may need servicing.
RCA 20F530T 20"... | Answered on Apr 30, 2009
Must be leaky processor
RCA 20F530T 20"... | Answered on Dec 03, 2008
If, when you turn down the color control all the way you have a black and red picture, then your picture tube is most likely weak and it's time to replace the set. If the black and white picture is normal, then the set could have a problem in the chroma circuit. Either way, it would not likely be worth repairing.
RCA 20F530T 20"... | Answered on Sep 25, 2008
on the kine board,( the small board plugged on the back of the tube.) look for and test rb030,rb050,rb070, all 3 resistors sould read 1000 ohm (or 1k ohm). I suspect one of there resistors are open. if not on ib001 (same board). you can check for these voltages. pin1 2.8v, pin2 2.9v, pin3 2.9v, pin4 0v (ground), pin55.9v, pin6 181v, pin7 104v, pin8 105v, pin9 111v. all voltages are in dc. hope this helps.
RCA 20F530T 20"... | Answered on Aug 29, 2008
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
RCA 20F530T 20"... | Answered on Aug 11, 2007
Hello Franchette, for what you describe, you have been unable to see the channels or have been deleted from the list of tuning of your TV
As a first step make sure that the antenna or cable video connection is in perfect condition, if you use a decoder, check on another TV that works well, check the interconnection cables between the decoder and the TV, if you can not solve, I sent you a link so you can download the user manual so that you follow the steps of tuning and controls the connections
I hope your information is useful and you can restore the channels on your RCA TV
Greetings Franco Dosil
Hola Franchette, por lo que describes, te has quedado sin poder ver los canales o se han borrado del listado de sintonia de tu televisor
Como primera medida aseg?rate que la conexi?n de antena o v?deo cable est?n en perfecto estado, si utilizas alg?n decodificador, comprueba en otro televisor que funcione bien, revisa los cables de interconexion entre el decodificador y el televisor, si no logras resolver, te envi? un link para que puedas descargar el manual de usuario para que sigas los pasos de sintonia y controles las conexiones
Espero te sea ?til mi informaci?n y logres restablecer los canales en tu TV RCA
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/32/3132/313174-rca/d52w15.pdf?9e9bd1856ed08ad674b2cc0c44c1c491&take=binary
RCA Televison &... | Answered 2 days ago
Hello Cherie, the RCA 98090, has no HDMI output, if it has composite audio and video output, through the RCA connectors on the right side of the DVD
To see it on your TV you would have to connect a cable of three RCA (Yellow, White and Red) from the DVD, to the AV input of your TV
I hope you can see the DVDs
Hola Cherie, el RCA 98090, no tiene salida de HDMI, si tiene salida de audio y v?deo compuesto , a trav?s de los conectores RCA del lado derecho del DVD
Para poder verlo en tu TV tendr?as que conectar un cable de tres RCA (Amarillo, Blanco y Rojo) desde el DVD, hasta la entrada AV de tu televisor
Espero puedas ver los DVD
RCA Televison &... | Answered 3 days ago
Almost certainly a bad motor. Visit your local Goodwill/rummage store/yard sale for a replacement unit. Parts are almost impossible to get and the cost to repair vastly exceeds its value.
RCA Televison &... | Answered on May 21, 2019
The only remotes that turns everything off are satellite remotes.
(Dish Network, Direct TV, Shaw, and Bell)
RCA Televison &... | Answered on May 19, 2019
RCA 20F530T 20" TV Logo
17 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
new sony dvd player
  • Televison & Video
