20 Most Recent RCA 24V511T 24" TV Questions & Answers
What does message catv 3 mono mean with a blank blue screen?
if the power was out you may have to reset the box or turn the box back on so that the signal can reach the tv receiver
8/28/2015 10:42:39 PM • RCA 24V511T 24"... • Answered on Aug 28, 2015
2answers
Only bottom half of the screen is showing...
Resolder IC301=TDA8177 mounted on a heat sink. This integrated circuit has 7 pins.
11/21/2014 11:05:47 AM • RCA 24V511T 24"... • Answered on Nov 21, 2014
The screen is only showing the bottom half.
Hi. Look for cold solderjoints on the vertical output section. Most likely, the vertical final IC has bad solderings. Using a magnifier, one can see "craters" around the soldering pin/pad. Or just simply re-do all of them. Good luck;
11/7/2014 7:25:51 AM • RCA 24V511T 24"... • Answered on Nov 07, 2014
Www curtisint com
If the tuner is weak, this kind of fault can occur. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
7/25/2014 2:45:33 PM • RCA 24V511T 24"... • Answered on Jul 25, 2014
New on button
What happened to this button? Provide more details, please. Gopakumar Gopalan Google
2/21/2014 3:29:29 PM • RCA 24V511T 24"... • Answered on Feb 21, 2014
Tv turns on sometimes and dont other times
Check and replace damaged component/s at its main power regulator [SMPS] board's start voltage section. Gopakumar Gopalan Google
2/21/2014 3:27:11 PM • RCA 24V511T 24"... • Answered on Feb 21, 2014
How do I configure for antenna (on-air) reception?
TV has to have an ATSC tuner. Should find it in onscreen menu. Otherwise, you will need a converter box. About $50 at big box stores.
1/18/2014 7:24:02 PM • RCA 24V511T 24"... • Answered on Jan 18, 2014
0answers
Rca 24v511t
Be the first to answer 11/25/2013 3:34:55 AM • RCA 24V511T 24"... • Posted on Nov 25, 2013Be the first to answer
No sound on some channels. One in spanish
Digital. I've had the same problem ever since everything went do digital.
10/21/2013 12:45:23 AM • RCA 24V511T 24"... • Answered on Oct 21, 2013
Unlock pin on hannspree 22
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
9/19/2012 11:59:14 AM • RCA 24V511T 24"... • Answered on Sep 19, 2012
How to unlock tv ece model
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on
4/4/2012 1:44:05 PM • RCA 24V511T 24"... • Answered on Apr 04, 2012
How do i unlock it
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.Lock the controls to activate the changes using item six on the "Parental Controls" menu
3/10/2012 4:59:27 PM • RCA 24V511T 24"... • Answered on Mar 10, 2012
Is RCA 24V511T digital
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
9/22/2011 5:53:18 PM • RCA 24V511T 24"... • Answered on Sep 22, 2011
Rca 24v511t tv is locked
Hello
To unlock the FPA lock, you must have its original remote control handset. If you haven't it now, just buy ome from the authorised service center for RCA at your town, or just borrow it from andy of your friends or relatives who owns the smae model TV.
To unlock try the folloing methods. One amoung them will surley unlock your tv.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. OK.
9/4/2011 6:31:46 PM • RCA 24V511T 24"... • Answered on Sep 04, 2011
Lost remote tv wont come
if the tv is like mine without a power button on the tv try a universal remote or order a new one from rca.
1/29/2011 7:24:37 PM • RCA 24V511T 24"... • Answered on Jan 29, 2011
I have a RCA model
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
1/7/2011 5:34:13 PM • RCA 24V511T 24"... • Answered on Jan 07, 2011
RCA 24V511T 24" TV Logo
Popular Tags
56 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
only bottom half screen showing
  • Televison & Video
