20 Most Recent
Orange SPV C500 Pocket PC Questions & Answers
Spv c500 simlock
the phone, comes with simlock and application lock, google to find sim unlocking softwares
I need a puk code for my orange phone LG ks360
Hi the PUK code is the security code for the sim card and not any code to do with the phone, all you need to do to get the PUK code is call your service provider.
your service provider wont charge for giving you the code as the code belongs to you, all you need to tell them is your phone number or if you dont know that then the number printed on the sim card, they will then provide you with the 10digit PUK code for free over the phone.
this will then allow you to access the sim card.
The only place you can get the PUK code from is your service provider as their is no where else that keeps these codes, if you still have the card the sim card was attatched to then it will be written on their but if you no longer have this then the only way your going to get the code is by calling your service provider, they wont charge you for this as the code belongs to you,
you do have another option open to you though, if you dont need that sim card then you can go out and get another sim card and when you get given a new sim card you will get given the unique PUK code it will be written on the card the sim card is attatched to.
let me know if you need further assistance ok.
plz rate this solution as i have a whole page of unrated posts, thanks
this code belongs to you so dont pay anyone to give you the code ok, so the best option would be to call your service provider over the phone and ask them for the PUK code, they will ask you for the phone number if you know it or if not they will ask you for the number written on the sim card, once they have this they will then be able to give you the code, this code will only work with the sim thats asking for the code, if you enter the wrong code more than a few times it blocks the sim card and it can no longer be used,
let me know if you have any problems
My SPV C500 does not
Please follow the instructions below:
On your SPV C500, press Start and select Settings.
Scroll to and select Bluetooth. Select Bluetooth again. Select On
Ensure the BT250v is turned off
Press and hold the Answer button until a solid blue light comes on
Select the BT250v from the list of found devices on your SPV C500 phone.
If this won't work please try a different phone ...and see if you get the same result.
Need puk code for orange
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
The phone is locked on flight mode
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
if not solved tell me your IMIE number
type *#06# on your phone to get IMIE number
Still Not Solved
Please type *#7780# to reset to factory settings.
NOTE:Restoring will delete all your datas.
When you give this code it will prompt for security code.Default security code is 12345.If you changed it please enter that code.
It will bring your mobile to factory settings
How do you find your puk code on your phone
You can not find your puk code on your phone but you can get on your starter pack or call your service provider.
The starter pack is the pack that contain the sim card.
Thanks
I need a puk code for a orange LG ks360
ahhh this happened to me last night you need to call your service provider and give them your account info and its a breeze they give you the password in a matter of minutes but don't keep trying and use up all 10 chances or it Fry's your sim card
How to Orange SPV C500 factry reset
1. Press and hold soft1 and soft2 keys.
2. Press and hold power
button for around 1 to 1.5 seconds. Release power button. Keep hold
3. Later, screen shoould show instructions to
ask user to press '0' key to reset to factory default.
4. Press
'0' within the timeout period, which is only several seconds only.
5. If no instruction is shown on the screen, repeat steps 1 to 4.
The timing is sensitive.
I need a puk code for my lgks360
You should contact your service provider and ask for the puk. They will ask you for some details that can be found either on the backside of your phone or the papers that came with the phone. Then they will provide you with the PUK.
I cant get on 2 my phone
The only wat to get your phone un-PUK'ed is to contact your provider this will always happen after 10 attempts on a PUK.
They should give you instructions on how to un PUK it
PUK code problems
Amy you need to phone up your network operator to get your puk code
