20 Most Recent
RCA RT2500 System Questions & Answers
RCA RT2500 will not turn on
press and hold power button while unplugging and plugging power supply cord may take a few tries worked for me
How come I don't get any sound from my RCA rt2500 audio receiver?
I've owned this receiver since the Summer 2001 and it worked well until the audio became intermittent several years later. Eventually, the unit was ON but all sound was dead. It turns out that there are solder joints that developed tiny solder breaks. These were found in the main power board on the large electrolytic capacitors and on the 7 power tab transistors that share a large square heat sink. Thermal cycling can cause microscopic solder joint breaks over years of use. After I re-soldered the broken joints the unit worked properly and is still in use in 2017. Consult a qualified electronics repair technician for the repair, which can be accessed via the removable panel on the bottom of the cabinet. Of course, be sure the unit is unplugged from AC power before starting your inspection and repair.
Receiver doesn't play sound until it's warmed up 5 - 10 minutes
Unfortunately, your question has too many variables. Try this. Unplug the unit. Plug it back in. When you first push the power button, you should immediately hear one mechanical click from the unit, followed by a second click with 5-10 seconds. If you don't hear the second click, the unit may have a condition known as DC Offset. It would be unusual to have DC Offset only within the first 5-10 minutes. It's possible that power supply has an issue where both the positive and negative voltages are not coming up at the same time.
If you are interested in having your RCA repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
After unit is on several minutes, sound turns to
I had this same problem, check the power transistors attached to the heat sink near the large caps, they tend to get cold solder joints after lots of heating and cooling. 15 minutes and good soldering iron will probably make a huge difference. I added extra cooling fins to mine to help dissipate the heat. hopefully wont go bad real soon again. Also check the large caps while your in there, maybe a good time.
