20 Most Recent
Samsung SIR-S300W DirecTV DTV Receiver Questions & Answers
Receiver on but not working
call direct tv and ask for a reset. When you do not use your receiver leave it on and connecetd or it will not receive updates and will forget what it once knew. Actually I think you can use the automated system and use (I think...not sure) code 712 to reset all your receivers with out waiting for help.
1/17/2017 6:57:46 AM •
Samsung...
Answered
on Jan 17, 2017
Lightning Damage
There are millions upon millions of electronics that could have been fried. If you wanted to try and frankenstein with other broken receivers from ebay you might be able to fix it. Also check to make sure there aren't any fuses and I recommend a surge protector.
10/15/2007 6:27:46 AM •
Samsung...
Answered
on Oct 15, 2007
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
