20 Most Recent
Samsung YP-T7Z MP3 Player Questions & Answers
Can't delete or copy files ?
yp-t7 is builded w protected switch,to prevent loss data,
u can switch that by click reset button when u is connecting on usb port
Player frozen
You should let the battery be flat and then charge it.
It'd then work. It happened to me twice. Hope this helps.
PLAYER DOESNT TURN ON
I am assuming the player turns on when connected via usb??? Some players can be powered by usb. A few things to look to try and narrow your problem. Does the menu work when connected to your PC? Does the unit indicate that it is taking a charge ie. a battery meter (like cellphones)when plugged in for charging. Can you turn the unit on while it is charging? Some more info will be helpful in determining the problem.
Forgot password
If this is about your Google account, click the "Can't access your account?" link on the Google sign-in page.
Samsung yp-u5 4gb connection
Use a toothpick to clean out the lint in the usb connector. If you use the mp3 player a lot without the cap lint will build up and cause misalignment when plugging it in the pc.
