20 Most Recent Samsung TSL3293HF 32" TV Questions & Answers
U have all the tools and also can do basic soldering work too?Yes.Than take the tv aparts.The tv video board,that the board connected to the tv CRT-(tv tube).Resolders all those CRT-(tv tube) sockets connections to video board.Resoldering all the sockets connections between the CRT-(tv tube) and the tv video board,problems will be solved.If not must trouble shoot all those capacitors components on the video board and replace them.
Samsung... | Answered on May 04, 2011
I HAD A REPAIR GUY OUT TODAY AND HE SAID IT WAS THE POWER MODULE. I HAVE NOT GOT A PRICE FOR THE PART OR REPAIR YET.
JASONCBFAN
Samsung... | Answered on May 02, 2009
If you have a conventional set, it sounds like you might have cold solder joints around the Horiz Driver Transformer. It's not the large one--the small one.
Samsung... | Answered on Jul 17, 2008
PROBLEM IS FLYBACK TRANSFORMER
Samsung... | Answered on May 30, 2008
Open internal fuse or power supply failure
Samsung... | Answered 19 hours ago
The Picture Off mode could be enabled if the picture is visible for a while. To check if this is the case, press any button on the remote other than power or volume. If it is, press Menu. Enter the Picture sub-menu and select Picture Off. Disable the feature. This feature is described in the E-manual for the 6350 series TVs here: https://www.samsung.com/us/support/owners/product/2014-led-tv-h6350-series . See http://www.manualsdir.com/manuals/421041/samsung-un32h5500afxza-un32h6350afxza-un50h6400afxza-un48h6400afxza-un65h7150afxza-un60h6350afxza-un65h6400afxza-un48h6350afxza-un40h5500afxza-un60h7150afxza-un46h7150afxza-un50h5500afxza-un75h7150afxza-un60h7100afxza-un55h6350afxza-un40h6350afxza-un55h63.html?page=163 for just the page on the picture off mode. If the picture is dim at times, check if the eco solution mode is enabled (System > Energy Savings).
If the screen is always dark, then the back light is not working. This can be caused by the failure of the LED back lights or the inverter that powers the backlighting. If you see a faint image when you shine a flashlight at the TV, this could the problem. The inverter usually fails before the LEDs. Replacing the inverter requires opening the TV and could have a shock risk. Replacing the backlighting requires separating the LCD panel from the bezel and getting between the layers at the edge of the panel.
I hope this helps.
Samsung... | Answered Yesterday
The Samsung TX card is used to send part of the audio signal from the main unit to the wireless module that controls the surround sound (rear) speakers for a Samsung Home Theater system. It isn't going to act like a ChromeCast device for your tablet.
The Samsung AH81-04177J (SWA-4000) is only compatible with a small number of Samsung Home Theater systems. see http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AH81-04177J.aspx . One of the supported systems is the Samsung HT-BD3252, https://www.samsung.com/us/support/owners/product/blu-ray-home-theater-ht-bd3252-series . See the manual of the home theater system for more information: http://downloadcenter.samsung.com/content/UM/201104/20110419185210639/HT-BD3252A_XAA_0807[1].pdf .
I hope this helps.
Samsung... | Answered 3 days ago
Samsung TSL3293HF 32" TV Logo
Popular Tags
12 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
tv trouble coming
  • Televison & Video
