20 Most Recent
Samsung TX-P3264 32" TV Questions & Answers
Ps3 hdmi to dvi blank
Sometimes the PS3 automatically outputs it's video and audio signals in composite form. Try going back to your original composite cables and setting your system to output in HDMI. Those options would be under "Display Settings". Hope this helps!
Why does my Samsung 32
The set is trying to start but it is detecting a problem so it keeps trying. Most likely you have a horizontal or high voltage problem. Hard to say. Have a shop check it out for you. Thanks
We don't have the original remote, but a
Check that you have selected "cable" instead of "antenna" as a signal source and then autoprogram the set. These features can usually be found through the on screen menu using front panel buttons.
Samsung plasma
the neck board of your tv tube has lose solder have it resolder.
Tv is not accepting remote control
to start with your tv will never work with your adoption as the company who made that set did not connect that part of circuit to the tv that circuit you found is a dummy what they call a plan blue print.and instead manufactured the tv a diffrent way.
Old tv samsung
try to check your audio video chord check it if it is open. you didnt mention if your tv has video channel (tuner). if your tv video channel is o.k then the problem of your tv is in the video switcher inputs. in this case you need a service technician.
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
