20 Most Recent Samsung TX-P2670WH 26" TV Questions & Answers
Hello, I have a Samsung
when plug on the tv only shows phillip then screen turned to black
1/13/2014 6:55:47 PM • Samsung... • Answered on Jan 13, 2014
I turned the tv on
hi
you have power suply problem could be a bad solder or capacitor
9/30/2010 3:20:22 AM • Samsung... • Answered on Sep 30, 2010
It turns off by itself.
Just look for bad capcitors will not cut it,
1. Check if the fuse has blown
if the fuse has blown you can replace it but if it blows again then you got power supply issues and you going to need ot take it down to a local tv repair shop.
just checking for blown caps is not goign to solve your issue or make new issues there are reasons why a cap would blow and you must follow up on those reasons like a bad relay, bad transformer ect ect.
let us know
Thanks Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
8/8/2010 3:46:02 PM • Samsung... • Answered on Aug 08, 2010
RE: Samsung 26" (CRT) HDTV won't turn on...
THe problem is not likely to be a defective part although that could be the case. I would first look for poor solder connections that would have been agrivated by any moves that you have made. If you can solder, resolder any connections on any board that appear grainy or have rings.
Keep me posted.
Dan
11/19/2008 10:25:01 PM • Samsung... • Answered on Nov 19, 2008
Since the set works some of the time, I'd first look for poor connections. One thing to keep in mind is when the set does NOT work properly. does that occur more frequently with heat? cold? Humidity? If you can solder, first try resoldering any connecitons on the boards that appear grainy or have rings. If that does not resolve the problem, look for patterns for when the set fails. Those patterns will help to narrow down the possibilities.
Keep me posted,
Dan
9/5/2008 11:22:15 AM • Samsung... • Answered on Sep 05, 2008
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
7/9/2008 6:48:07 PM • Samsung... • Answered on Jul 09, 2008
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM • Samsung... • Answered Yesterday
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/17/2024 5:31:49 PM • Samsung... • Answered on Apr 17, 2024
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered on Apr 14, 2024
Samsung plasma tv repair PN51F5300BFXZA
All I can advise is to take it to an authorised Samsung repair shop. A list is available on the Samsung web site.
4/7/2024 8:20:50 AM • Samsung... • Answered on Apr 07, 2024
2answers
Samsung VHS VR8360C - if i use a three colour av cable on the VHS end and go to an HDMI connector at LG tv end will this work or do I need a converter?
The old yellow, red, white RCA cables are analogue signals, while HDMI cables only carry data. They are in no way compatible. You can buy active conversion boxes that will convert analog to digital, but simple cables cannot work
3/23/2024 10:44:12 PM • Samsung... • Answered on Mar 23, 2024
Remote code for Samsung remote to LG tv
It can't be done. The Samsung remote will be single frequency for that Samsung device only and the LG remote for that television (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 3:17:28 PM • Samsung... • Answered on Mar 19, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead. What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame. It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM • Samsung... • Answered on Feb 05, 2024
2answers
A resistor got burned on my samsung HT-E330K. I do not know its value because it got burned. Does anyone knows what it is?
Can you tell this power supply board zener doide value?
2/5/2024 2:11:29 PM • Samsung... • Answered on Feb 05, 2024
2answers
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described. Here are a few options you might consider:
  1. Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
  2. Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
  3. Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
  4. Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
  5. Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM • Samsung... • Answered on Feb 04, 2024
Samsung TV went blank and won't turn on
2/2/2024 8:15:51 AM • Samsung... • Answered on Feb 02, 2024
Samsung plasma model PN60F5500, has sound, no picture
See troubleshooting section of user manual for help Troubleshooting - Samsung PN51F5500 User Manual [Page 21] ' ManualsLib
1/30/2024 7:50:08 PM • Samsung... • Answered on Jan 30, 2024
Samsung U55HU9000 curved LED with intermittently displaying green vertical lines. Vanishes after an hour. Power supply issue?
Possibly, or dry joints, or failing Caps. Get your meters and oscilloscope out. ..
1/28/2024 11:17:04 PM • Samsung... • Answered on Jan 28, 2024
3answers
How to reset samsung UE55D7000
Hold down the EXIT button for 30 seconds
1/25/2024 9:25:07 PM • Samsung... • Answered on Jan 25, 2024
Samsung TX-P2670WH 26" TV Logo
8 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung tx p2670wh 26 tv squealing
  • Televison & Video
