20 Most Recent
Samsung LE32A41B 32 in. HD-Ready LCD Television Questions & Answers
Samsung LE32A436T no picture
Visit the site named 'Electro-help' for more
details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 990 posts to different brand TVs now. Pull up older posts there.
Hi, I was woundering if
Hi:
Check the power supply ro4 puffy capacitors that look like they are about to burst on their tops, ususally there are two of them that will cause this problem. Replace with same value but change the voltage reating on the capacitor to 16volts.
Hi,WHAT SCREWS DO I NEED TO PUT IN THE BACK OF MY
If the set size match the size of the bracket it should have fit, I would look on back for a screw that is already in set and see if it fit the holes you need, if so then you can use them if you have atleast four, if not then take that screw to a local store and match it up.
I would like to delete
It sounds to me like you need to block the channels on the converter box for freeview. The television parental control will only work if you are using basic cable hooked directly into your tv. Otherwise, all of the channel control functions are handled by the control/converter box from your service provider. If you do have cable hooked directly into your set, try consulting the owners manual either online or the copy provided with the television. Good luck, Russmann.
TV Type is a Samsung LE32A41B
Hi.
The TV entered into shop mode (a service mode) the feature that had been activated is now displaying each half of the screen in a different mode, to show TV capabilities.
To get out of the shop mode hold the menu button on the side panel down for 8 seconds.
To get to full service menu the procedure is instead:
POWER to turn the set off
INFO - MENU - MUTE - POWER in that order.
Or the following:
With the unit on, try holding down the remote's EXIT button for 12 seconds, and see if you are prompted to RESET. If you are, key up to YES and see if that fixes the issue.
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
