20 Most Recent Samsung LTM1755 17 in. HD-Ready LCD Television Questions & Answers
I had a 26" Samsung LCD that wouldn't turn on, and the red light stayed on too, so I knew it was getting power. I found some info out there and figured out how to fix it. Also made a video to show others. I'm a complete newb so if I can do it, I know a lot of others can too. Make sure you research stuff and be safe when fixing it. I take no responsibility if you mess up your own TV! But like I said, I fixed it, so I figured almost anyone can. Also, it only cost me $1.40.
http://www.youtube.com/watch?v=vWKlex7kA7A
Samsung LTM1755... | Answered on Sep 08, 2016
The Main bd is bad. It is not sending a turn on signal to the power supply.
Samsung LTM1755... | Answered on Oct 18, 2014
Greetings. I have a Samsung LN26A450, turn on and normal listening but no video, the screen is black. I opened it and found the F4 in the inverter card open, stamped value says "15" on the board says "0.75A/76V", I put that value and reopen, maybe the value is 1.5 A or 15A ?. I measured most components in the board and are ok.
Samsung LTM1755... | Answered on Sep 27, 2012
Repair the Power Supply. Should just be bad Caps,
Samsung LTM1755... | Answered on Nov 25, 2010
check capacitors in power supply if they swollen from top replace them.
Samsung LTM1755... | Answered on Jul 02, 2010
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
Samsung LTM1755... | Answered on May 23, 2010
Replace the Power Supply.
Samsung LTM1755... | Answered on Apr 16, 2010
The power supply in many of Samsung’s TV's have capacitors installed that are rated for 10v that feed a 12v bus causing them to bulge or fail. If you are out of warranty, get someone who understands electronics to fix it.
Samsung LTM1755... | Answered on Mar 13, 2010
is inverter board defective, needs to be replaced. send to repair
Samsung LTM1755... | Answered on Feb 20, 2010
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Samsung LTM1755... | Answered on Jan 19, 2010
sounds like your PSU board is bad. you can replace the board itself or just the faulty components.If you are not inclined to this type of work I recommend calling a service tech.
just remember to unplug it because it will hurt if you zap yourself.
Samsung LTM1755... | Answered on Oct 16, 2009
be more specific, does it have any led light on the front
Samsung LTM1755... | Answered on Jul 18, 2009
i had a similar problem with a 47 inch vizio lcd t.v. It would be fine for a while then all of a sudden the black areas and shadows would all become red lines in theses areas. I brought it back to the guy who i had purchased it from and he had told me that the reason for the lines was a bad video card.i got a new set and it works just fine.So i would reccomend getting a new card or sending it back to the manufacturer for them to install a new one for you. hope this helps.
Samsung LTM1755... | Answered on Jun 11, 2009
hi Kiril,
the culprit here is the starter capacitor. this may have been blown or currently leaking. This capacitor can be replaced and is usually near the power supply of the TV. Samsung parts can easily be found on any TV repair center so you may want to take a note of it.
if the device is still under warranty, best move is to have this go through warranty to make sure of a quality repair from samsung techs
regards,
voodoo
Samsung LTM1755... | Answered on Jun 09, 2009
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
Samsung LTM1755... | Answered on Apr 17, 2009
On the back of the tv at the top of the stand will be four silver screws, remove those with the set laying on it's face or the tv may fall over. after those are removed the stand will slide out of the bottom of the tv. Hope this helps.
Samsung LTM1755... | Answered on Apr 02, 2008
Samsung LTM1755 17 in. HD-Ready LCD Television Logo
36 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung lcd tv ltm1755b turn power light
  • Televison & Video
