20 Most Recent
Apple iPhone 7 Plus Questions & Answers
How to Install Cydia without Computer?
It's impossible to download and install CYDIA without a P. C.
First , your i device must be jail broken and that to requires a computer. The real Cydia by Jay Freeman (saurik ) can only
be obtained with a jailbroken I device using a software tool like
Pangu ,or TiAg.., or Evasion . These are downloaded free of course using your idevice only and will only open and work when you plug into a p.c. with a USB cable from that I device. SORRY.
There are some emulators you can install and there is a Cydia on one of these apps and is called - inocydia.net . But there are a couple of things you do to get the app . And is ok actually because there are some apps in these stores as well that are useful to me ,
although they may not be useful to you ,after you get the
Web apps app stores and the inocydia app , you can delete the others that will be needed for the Cydia web app.. I use them and are perfectly safe to use . I use to have Cydia on one of my iPad 2 . I have many i devices and although the one I'm referenceing To is jailbroken still I opted after 3 years to delete Cydia. It's a pain in the rear , it crashes constantly , you have to jump through to many hoops to get a tweak ,or add this then add this to complete a
complete a theme , Blah blah blah .....to me........its to time consuming and so frustrating, to fix or respring and reset all the settings and wifi code than to get an app and use for few days only to tuck it in a folder i call "Rarely used apps I hate " or the other
folder that I labled " kicked to the curb " that when in this folder , these apps will never see daylight again . I only open it to put things in .......never to come out .huhuhaha
So if you want the links and the procedure or steps to download and install these useful App Stores Alternative s , follow up on my answer to your post ...and this way I will provide all the links and direction for download and installing . It's a bit tricky in the order of what step is used but very simple in the process . So there Ya go
and I hope this will help .. Best to Ya .later on MUCHACHO,
A. Goodwin
How can you fix sim lock on an iphone?
Make Sure your iPhone asking for sim unlock code after insert a non accepted sim card( For Ex. if you are using AT&T sim insert the T-Mobile sim in this)If yes then follow the steps below:go to the
www.unlockninja.com and select as per your requiremnetBrand Name:-Model No or Name:-Country from The Phone Purchased:-Network on which The Phone Is Locked:-Mail ID:-place order to unlocking confirmation at https://www.unlockninja.com/unlock-apple+phone and wait for the giving time that is 30 min to 2 daysYou will confirmed via mail as the phone has been unlocked. Then you only need to follow the steps below:How to fix sim lock in apple iPhoneHow to Unlock the Apple iPhone 6 after getting the confirmation as Unlocked-Install the last version of iTunes on your computer.-Make sure your iPhone is updated with the lastest version of iOS.-Switch ON your iPhone 6 with a SIM Card from a non-compatible network.-Connect your iPhone 6 to your computer using the Original USB Cable.-Launch iTunes andwait until iTunes detect your iPhone 6.-Now disconnect your iPhone 6sand reconnect it after 10 seconds.-Your iPhone 6 is now Unlocked!Note:-In the unlikely event that your iPhone 6s is not unlocked, please restore your device following the official guideline from Apple - https://support.apple.com/en-us/HT201252
Please help me to recover my apple id and password
- Go to Settings.
- Tap [your name] > Password & Security > Change Password.
- If you're signed into iCloud and have a passcode enabled, you'll be prompted to enter the passcode for your device.
- Follow the onscreen steps to update your password.
- good luck
How do I make ringtones work on my phone after I download them?
I've learned one way that I can turn any song that I have in ringtone.
You need first cut your song using the Itunes and later alter the extension of new song that you have created for the same extension permitted the itunes.
The same extension of the ringtone what you already have in your iphone.
After this is only import the song to itunes and pass to iphone in the normal process.
