20 Most Recent
Air Conditioning and Heat for Kia Rio Questions & Answers
Air not getting cold
You need to install dye then check connections with detector. You probably have a bad o-ring seal or most likly a loose connection. Try tighting all connections
An notification sound on my 2016 Kia Forte5 LX
for heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
tried and tested !
Hi, I have aKia Sedona
Hello Ray! First let me say, although I’m not aphiliated with anyone at Kia. You have a fine vehicle! If I’m understanding you, your unable to shift into fourth gear until you’ve been driving for 30 minutes. Im assuming you mean 30 mph. This transmission will not alow you to down shift at
05 kia spectra override button
sometimes the wire breaks off inside the shifter remove switch and check wires or take off the center consol and check wires if not broken inside tube but if the lights on dash flashes problem from tcm causes disengaging the overdrive and making it not functional you need a scanner to find the code or remove the battery cable for 15 mins to erase all codes and see if it works if not you need scanner
Dealerdisable 2m security sysstem 2012 kia sedona
you need a scanner to be able to unlock the system and sometimes a code will be needed to have control over the adjustments usually they call the tech line with serial number and the tech gives a authorize code to secure the system should be guarentee 3 yrs 60 km or 5 yrs 100 km
How to put spark plugs in car
you have 4 black wires6 milimeters top of your engine take 1 of fit one in then 2nd comblete 3th and 4th you need spark plug socket go an clock wise. check the gap.
