20 Most Recent Transmission & Drivetrain for Kia Amanti Sedan Questions & Answers
What cause the transmission not shift in drive
Try the easiest possibility first.....check the fluid level.
9/5/2014 1:39:31 AM • Transmission &... • Answered on Sep 05, 2014
0answers
How do I remove the rear door panel on a 2009 KIA Borrego ?
Remove all visible screws first on handles, etc. then you should be able to pop the panel off as it should be held on by clips.
1/15/2023 8:24:47 PM • Kia Vehicle... • Answered on Jan 15, 2023
An notification sound on my 2016 Kia Forte5 LX
for heavy machinery cars etc. luckily there are many websites that can help you repair for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic tried and tested !
1/24/2019 9:59:04 AM • Kia Vehicle... • Answered on Jan 24, 2019
Hi, I have aKia Sedona
Hello Ray! First let me say, although I’m not aphiliated with anyone at Kia. You have a fine vehicle! If I’m understanding you, your unable to shift into fourth gear until you’ve been driving for 30 minutes. Im assuming you mean 30 mph. This transmission will not alow you to down shift at
2/3/2018 2:55:58 PM • Kia Vehicle... • Answered on Feb 03, 2018
Noice from the gear
Change the oil and the filter to see if this helps to remedy ghe problem.
9/15/2017 9:23:51 PM • Kia Vehicle... • Answered on Sep 15, 2017
05 kia spectra override button
sometimes the wire breaks off inside the shifter remove switch and check wires or take off the center consol and check wires if not broken inside tube but if the lights on dash flashes problem from tcm causes disengaging the overdrive and making it not functional you need a scanner to find the code or remove the battery cable for 15 mins to erase all codes and see if it works if not you need scanner
9/6/2014 1:48:41 AM • Kia Vehicle... • Answered on Sep 06, 2014
Dealerdisable 2m security sysstem 2012 kia sedona
you need a scanner to be able to unlock the system and sometimes a code will be needed to have control over the adjustments usually they call the tech line with serial number and the tech gives a authorize code to secure the system should be guarentee 3 yrs 60 km or 5 yrs 100 km
9/6/2014 1:26:29 AM • Kia Vehicle... • Answered on Sep 06, 2014
What causes the indicator to indicate fast ?"
Most likely a bulb has blown
8/31/2014 5:54:55 PM • Kia Vehicle... • Answered on Aug 31, 2014
Kia starter will not turn
Check all electrical connections to starter. Starter solenoid or starter could be worn out.
8/19/2014 1:15:58 PM • Kia Vehicle... • Answered on Aug 19, 2014
2answers
How to put spark plugs in car
you have 4 black wires6 milimeters top of your engine take 1 of fit one in then 2nd comblete 3th and 4th you need spark plug socket go an clock wise. check the gap.
6/13/2014 4:37:00 AM • Kia Vehicle... • Answered on Jun 13, 2014
Rpm fluctuate in 04 kia sadona
Throttle position sensor
3/2/2014 6:51:53 AM • Kia Vehicle... • Answered on Mar 02, 2014
0answers
Does $1200 sound like too much to replace both
Depending on the make but you would be looking at around 4 hours and parts. I would be thinking it is around $300 too much. Get other quotes to work out the best price.
8/22/2013 11:06:52 AM • Kia Vehicle... • Answered on Aug 22, 2013
0answers
0answers
Kia sedona heater blows cold air
Could be your thermostat is stuck opened or your heater core is bad,
11/28/2012 12:24:25 AM • Kia Vehicle... • Answered on Nov 28, 2012
My 2004 kia amanti will only make a loud clicking noise when i try to start it. it sounds like the starter is stuck.
You have a bad starter from what you are describing. Did this just happen all of a sudden? Or has it been happening until the car died?
7/30/2012 5:35:08 AM • Kia Vehicle... • Answered on Jul 30, 2012
Transmission & Drivetrain for Kia Amanti Sedan Logo
2 questions posted
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Kia Vehicle Parts & Accessories
Most Popular Question
cause transmission not shift in drive
  • Vehicle Parts & Accessories
