20 Most Recent
Samsung SP-R4232 42 in. Plasma HDTV Questions & Answers
My samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply.
Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse.
If: Then:
It checks bad. Replace it.
It goes out again. Call a Servicer.
It is good. Check for the five volts that goes to the Main PCB.
No five volts, change the power suppy (SMPS)
Five volts is there, more than likely the Main needs replaced and SMPS.
For a Samsung Servicer in your area:
1-800-SAMSUNG
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses.
Green snow now black screen
It could be the logic but also the Y main. Probably should let a pro take a look it could be an expensive guess. Either circuit will cost you a few hundred. Good Luck
Blue fuzzy screen
Sustain fault suspected. If you wish to get more details, check this site. It has screen shots to defective plasma TVs, and you can compare them to that of yours. It will be best.
Pull up previous posts by its left sidebar, or
type in the
brand name and model number to of your set, to its
search box, and press '
Enter' or view it in
Mosaic /
Timeslide option.
Inverter
The blinking blue light are fault indications. From the number of blinks that occurs at one time switch ON, you can get an idea about the faulty circuit section inside it. Even though you've got this idea, service to Plasma TVs are somewhat difficult one for a user, who do not have any knowledge in electronics. If you wish to get more details, surf the following
link. There are over two thousand and
four hundred posts. All are related to
television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. Blinking codes to Samsung Plasma Displays are described in detail by one among the posts. Pull up older posts.
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
