20 Most Recent
Alcatel Speed Touch USB (3EC18607GA) Modem Questions & Answers
Hello i am trying to
When you download files into computer care has to be taken to where you do the download so that for playback you go to the correct folder. Otherwise you will be SOL till you find them.
Computer wont restart
try booting up in safe mode and run Disk Clean up, and run a Virus scan, and anti-spyware scan, update all system drivers. and scan for disk fragment faults
How can you speed up an alcatel usb modem, can it
A dialup modem can only go as fast as the phone line it's plugged in to, up to a theoretical maximum of 56kbs. If you live a distance from the exchange, or have a noisy phone line, the speed will be affected.
Alcatel Speedtich Modem and Microsoft Vista
hello
this modem are verry old but works normaly good
if you have setup cd you can try to install it if you dont have modem drivers cd download them or the best are to buy a new modem also with wireless posibilitys
not verry mutch monny
or buy one on ebay or site like these mostaly cheeper than in a store
if you buy in a store you wil also have waranty or you can chanche it
Portable divice
Make sure the phone is in usb mode. If it doesn't have a usb mode then plug the phone in like you normally would. On the dashboard, go to My Xbox then go right to video library, once there, you should see a section called portable device. If this doesn't work, please repost your question and list your phones, make and model.
I can't get photos' from my phone to pc using USB wire
Hai,
It is possible to connect the device and make it appear as a removable disk or mass storage device. The same as connecting a USB drive to the computer. To do that, go to Start > Settings > USB Connection mode on the phone. Choose Mass Storage and My storage in the drop down list. If you have a storage card, it will alse appear in that list. Now, all you have to do, is connect your device, open Windows Explore on the computer to copy/paste your pictures to the location you want. Again, this is a much faster way to transfer a lot of files rather than using WMDC to sync.
Mains power connection and download speed problems
This is only a suggestion you might want to replace the modem after all you have had a good use out of it I think its finally tiring out?
REPLACE IT you'll have much more fun with a newer one not to mention YEARS of fun.
My alcatel lucent is stuck on the initialisation mode where it keeps displaying **4029 v3.80.90**
Here are some steps you can try to resolve the issue:
Reset the phone: You can try resetting the phone to its factory settings. To do this, you need to press the "Menu" button, select "Settings," then "Phone Settings," and finally "Reset Settings." This should reset the phone to its default settings.
Update the firmware: If resetting the phone doesn't work, you can try updating the firmware. You can download the latest firmware from the Alcatel-Lucent website . Once you have downloaded the firmware, follow the instructions provided by Alcatel-Lucent to update your phone's firmware.
ALCATEL-LUCENT 4029 OPERATION MANUAL Pdf Download ' ManualsLib
If neither of these steps work, it might be best to contact Alcatel-Lucent customer support for further assistance.
10/28/2023 4:06:45 PM •
Alcatel...
Answered
on Oct 28, 2023
Cannot upload photo to pc
Please send your question in more details.
1) What device you are using to upload photo to the PC;
2) How is the device connected to your PC, by wired, or by wireless connection?
3) If by wired, the method of connection, i.e. direct connection without router, or connected via router; or via USB connection
4) what program is your device using to transfer the photos? e.g. wi-fi direct, blue-tooth transfer etc.,
5) how large is the size of your photo going to upload?
After getting all these information, then we can sort it out for you one by one the possible solution.
3/6/2022 11:31:25 AM •
Alcatel...
Answered
on Mar 06, 2022
