20 Most Recent
Cooling System for Audi A6 Questions & Answers
What are the probable causes of DTC P2181?
code p 2181 refers to cooling system performance--=== causes---radiator---coolant thermostat---engine coolant blower motor---ECT (engine coolant temperature) sensor
If there was no indications of temp problems before the code , I would be looking at replacing the sensor first as it reports coolant temperature to the ECM which turns on the fan and adjusts the air/fuel mixture according to engine temperature
Where is the camshaft sensor in 98 explorer
for heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
Save money
Doing research after spending a lot of money at the dealership I have found a lot of sites where you can download free information to DIY if you don't have the tools most automtive stores have a rant a tool program. Needless to say my husband has been very busy. Just make sure you are dealing with a site that has good reviews. Also eBay has parts and they arevalot cheaper than buying them from the dealership.
Location of camshaft position sensor 98 gmc 1500
Hello!
i have excellent luck joining forums or user groups for all the stuff abound my house, including my electric tooth brush. Many helpful members will walk you through your questions!
best wishes.
1988 dodge dakota sensor overheats
Does it loose power? You can have a overheating in the coolant sensor and oil is not hot... this usually is a problem with the joint of the head of the motor leaking pressure to coolant circuit.
BR
Cam shaft sensor
his might help, check out youtube,,,,
Jeep Grand Cherokee 2007 Laredo 3.7L V6 - Replacing Crankshaft and Camshaft Position Sensors
