20 Most Recent
Tao New Scooter 50cc Street Legal New Look Questions & Answers
2018 Taotao ATM50A1 gy6 139QMB scooter no spark..
all mc and cycles here have spark cut out for..
not in neutral ,
clutch not held in..
bar kill switch. tripped super easy that.
kick stand kill switch.
key switch bad.
(this is generic answer.)
ICM bad, or its crank sensor bad.
blown fuses.
bad wiring
buy the service manual and study spark there.
for sure what charges up the coil to make spark.
ICM is what it there most times; ign, control module
Is it possible that a 50cc Chinese scooter will continue Spark the spark plug rather than fired at each timing point. As a result rather then start it kicks back on the starter
being a 50cc engine it should have only 1 piston
If it is a 2 stroke , it will fire every time the piston comes to tdc
if it is a 4 stroke it has to have a timing point that excites the ignition system for every 4th stroke tdc
if the exciter receives a signal to fire the plug at the wrong time , it is getting that signal from a fault or incorrect timing
that fault can be
loose wire/s,worn unit that controls the timing ( distributor fault), loose flywheel , flywheel touching coil,incorrect timing (180 degrees out ) stator loose ,rotor loose,faulty crank position sensor
it is good practice to have a workshop manual on hand and if you don't have one go google and type in --workshop manual for 50 cc tao scooter--and see if there is a pdf version in english to download
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
Charger not working plug in light stays green, but battery is not charged
I have got 3 different chargers for my scooter. It's a Tifgalop T108. The charger light would stay green on the new chargers. My old one was the only one that was charging it. While I was replacing the charging ports, I came to find out that the negative wire is in a different location on the new ports. The negative wire was on number 3 on the old ones and is in number 2 on the new ones. After changing the ports all my new chargers work fine now.
Boots skincare jill nowak
Hello there,
"Boots" is a well-known pharmacy chain in the UK, and they have their own line of skincare products. However, "Jill Nowak" does not appear to be directly associated with Boots skincare.If you're looking for information about skincare products from Boots, you might want to explore their own-brand products or specific lines they carry. For personalized skincare advice or recommendations, consider consulting with a dermatologist or skincare specialist who can provide guidance tailored to your specific needs and concerns.
