20 Most Recent Apple At&t Iphone Factory Unlock Code Service 3 4 4s 5 5c 5s Clean Imei Only Questions & Answers
2answers
I need a unlock code for my iphone 5c att
sorry if you dont know it we dont know it or have access to it or any of your personal files or accounts you can try to get assistance from your provider but if you bought an icloud locked phone you basically bought a parts phone
9/23/2016 6:50:41 PM • Apple At&t... • Answered on Sep 23, 2016
2answers
How can you fix sim lock on an iphone?
Make Sure your iPhone asking for sim unlock code after insert a non accepted sim card( For Ex. if you are using AT&T sim insert the T-Mobile sim in this)If yes then follow the steps below:go to the www.unlockninja.com and select as per your requiremnetBrand Name:-Model No or Name:-Country from The Phone Purchased:-Network on which The Phone Is Locked:-Mail ID:-place order to unlocking confirmation at https://www.unlockninja.com/unlock-apple+phone and wait for the giving time that is 30 min to 2 daysYou will confirmed via mail as the phone has been unlocked. Then you only need to follow the steps below:How to fix sim lock in apple iPhoneHow to Unlock the Apple iPhone 6 after getting the confirmation as Unlocked-Install the last version of iTunes on your computer.-Make sure your iPhone is updated with the lastest version of iOS.-Switch ON your iPhone 6 with a SIM Card from a non-compatible network.-Connect your iPhone 6 to your computer using the Original USB Cable.-Launch iTunes andwait until iTunes detect your iPhone 6.-Now disconnect your iPhone 6sand reconnect it after 10 seconds.-Your iPhone 6 is now Unlocked!Note:-In the unlikely event that your iPhone 6s is not unlocked, please restore your device following the official guideline from Apple - https://support.apple.com/en-us/HT201252
6/14/2022 9:41:12 AM • Apple iPhone... • Answered on Jun 14, 2022
14answers
How to transfer contacts from Samsung to iPhone 6/6 Plus?
You just need a simple Android-iOS transfer tool. According to my personal experience, SynciOS Data Transfer can be a good choice. You can transfer your contacts, photos, musics, messages and so on by one click. transfer-contacts-from-samsung-iphone-6-o0ts2dao4vkjqmwacjadhqtp-5-0.jpg SynciOS Data Transfer For Windows
6/2/2022 10:30:17 AM • Apple iPhone... • Answered on Jun 02, 2022
2answers
Please help me to recover my apple id and password
  1. Go to Settings.
  2. Tap [your name] > Password & Security > Change Password.
  3. If you're signed into iCloud and have a passcode enabled, you'll be prompted to enter the passcode for your device.
  4. Follow the onscreen steps to update your password.
  5. good luck
4/5/2022 7:26:09 PM • Apple iPhone... • Answered on Apr 05, 2022
2answers
How do I turn the ringer on my apple4s on or off?
On the left side of the iPhone screen you have a switch that works for ring on and ring off
3/14/2022 7:11:36 AM • Apple iPhone... • Answered on Mar 14, 2022
2answers
How do I make ringtones work on my phone after I download them?
I've learned one way that I can turn any song that I have in ringtone. You need first cut your song using the Itunes and later alter the extension of new song that you have created for the same extension permitted the itunes. The same extension of the ringtone what you already have in your iphone. After this is only import the song to itunes and pass to iphone in the normal process.
3/5/2022 8:09:57 PM • Apple iPhone... • Answered on Mar 05, 2022
The time is not sync'ed with iphone. why or how do I corrent?
Go to "General," then "Date & Time" in the "Settings" app. Toggle the "Set Automatically" switch to the ON position (if this is already set ON, turn it OFF for about 15 seconds,unpair your Apple Watch then toggle it back ON to refresh) Make sure your Time Zone is set correctly for your location.
3/5/2022 8:09:26 PM • Apple iPhone... • Answered on Mar 05, 2022
2answers
How do u fix a iphone4 to make it update
There are several methods to update iPhone and following below steps can help you to reach this aim easier. How to Update iPhone Software Wirelessly If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
  1. Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
  2. Connect your iPhone to a WiFi network.
  3. Tap "Settings > General > Software Update" successively.
  4. Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
  5. Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
How to Update iPhone Software with iTunes If you can't update iPhone iOS software wirelessly throug WiFi connection, you could give iTunes a try. As the all-inclusive iOS device manager center, iTunes provides multiple effective assistances for you, including: backing up iOS devices, restoring iOS devices, transferring iOS data files, and updating iOS devices. You could follow the below steps to learn how to update iPhone software with iTunes in detail:
  1. Install the latest version of iTunes on your computer.
  2. Connect your iPhone to your computer via the USB cable.
  3. Open iTunes and select your device.
  4. Click "Summary > Check for Update".
  5. Once iTunes detects the available update, click "Download and Update".
  6. If asked, enter your passcode. Then iTunes would start to update iPhone iOS software. When it's finished, disconnect your iPhone with computer.
For more methods, check: How to Update iPhone
11/24/2021 6:25:50 PM • Apple iPhone... • Answered on Nov 24, 2021
2answers
How to transfer pictures from iphone 4s to facebook?
Download Facebook app on your iPhone 4s or plug your phone into your computer.
11/17/2021 2:54:13 AM • Apple iPhone... • Answered on Nov 17, 2021
2answers
Ringtone to be set in iPhone
Ringtones can be set for the whole phone in Settings-->Sounds-->Ringtone. You can set a ringtone for each of your contacts by editing the contact in the Phone app or the Contacts app. When you touch the "Edit" button when viewing any individual contact, you can assign a specific ringtone and vibration, and text tone and vibration, to that contact. If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
11/10/2021 7:16:48 PM • Apple iPhone... • Answered on Nov 10, 2021
8answers
How to wipe iPhone cleanly
"Erase all content" means all of YOUR content, including all applications you have downloaded and all the data for those applications and all the data for Apple applications (i.e. Mail, Photos, Calendar, Safari, etc.) will not be completely removed from the device, they still remain on your iPhone and can be easily recovered by some iPhone data recovery. I highly recommend you to try Safewiper iPhone data eraser app to complete your iPhone data, it will be the best choice when you need to sell your old iPhone or iPad. How to Permanently Erase Contacts from iPhone Before Selling
10/14/2021 3:49:54 AM • Apple iPhone... • Answered on Oct 14, 2021
4answers
Transfer iPhone photos to home computer
When you connect your iPhone to your computer you can access the photos that are on there on your desktop. If you have a Mac they will already be in iPhoto waiting to be imported. If not then you can just click on your iPhone in My Computer and you can access the pictures that way.
9/30/2021 4:06:35 PM • Apple iPhone... • Answered on Sep 30, 2021
3answers
How can I make my iphone go faster?
You can try these tips & tricks to speed up your iPhone.
  • Delete large apps that take up a lot of space
  • Get rid of old photos videos and music
  • Remove old text message
  • Empty Safari's cache
  • Close all the background apps
  • Turn off auto app updates
  • Turn off automatic downloads
  • Disable Location Services
  • Restart your iPhone every once in a while
  • Reset your device completely
And a complete cleaning for your iPhone is also needed, PhoneClean is such a professional cleaner made to remove junk files from your iPhone to make it run faster. How to Make Your iPhone Run Faster
9/18/2021 12:25:56 PM • Apple iPhone... • Answered on Sep 18, 2021
5answers
What is the Simplest way to Fix iPhone Error Codes 4013?
Try this way to fix iPhone Error Codes 4013. Solutions to Repair iTunes and iPhone Errors
8/19/2021 9:49:39 AM • Apple iPhone... • Answered on Aug 19, 2021
3answers
Why is my iphone is too slow -- please help me fix it
Maybe you run too many apps in the background, you can turn off background apps refresh. Too many junk files and caches, have a clear on your iPhone. There may no enough place on iPhone, delete some big files. More info: Why Is My iPhone So Slow and How to Fix It
8/13/2021 2:25:05 AM • Apple iPhone... • Answered on Aug 13, 2021
3answers
Apple itunes
You have a situation where your phone needs to be recovered by plugging it into the computer where you sync it to iTunes. When you do this a prompt will come up on your computer that you have connected to an unidentified iPhone. It will ask you if you want to restore it from your last backup, or initialize it as a new iPhone. I recommend that you restore to the last backup, so you don't have to go to the iTunes and App Store to reinstall all your apps. The bad news is that if you have never backed up to a computer, your journey to recover your digital life is going to be difficult.
8/4/2021 9:43:33 AM • Apple iPhone... • Answered on Aug 04, 2021
3answers
Cannot get downloaded ringtones from computer to iphone
Open itunes and drag those ringtones to itunes library once they dragged in try to play them. After they play you just need to connect your phone to computer and sync should start automatically.
8/3/2021 2:35:15 AM • Apple iPhone... • Answered on Aug 03, 2021
4answers
How do I retrieve photos sent to me on my iPhone through SMS?
Recently, I found a powerful tool - iOS Data Recovery software. .It The following steps will teach you how to retrieve photos from icloud. Step 1. Download the iPhone Data Recovery on your computer and install it first. Step 2. Choose iCloud Backup File and sign in your iCloud Account Step 3. Enter the program and choose any of them you want to get back and click the "Download" button. After downloaded the files, click the same button to start extracting. Step 4. Click "Camera Roll" on the left side of the window, and then preview the record. Choose what you want to recover. You will get back deleted photos after clicking "Recover". I believe iPhone Data Recovery must do you a great favor.
6/4/2021 2:05:14 AM • Apple iPhone... • Answered on Jun 04, 2021
15answers
How to Recover Lost Photos on Iphone?
If you are the crazy fan of Apple, you will know that deleted photos HELP NUMBER +1 833 272 0777will be saved on the DELETED folder for 30 days.
5/19/2021 2:50:54 AM • Apple iPhone... • Answered on May 19, 2021
3answers
ITunes no longer recognizes my iPhone 5, running Windows 10
You may upgrade your iTunes to the latest version to have a try or you can use a nice alternative to iTunes for iPhone to sync your data to PC. Top 3 free iTunes alternative for iPhone
4/27/2021 6:00:43 AM • Apple iPhone... • Answered on Apr 27, 2021
Apple At&t Iphone Factory Unlock Code Service 3 4 4s 5 5c 5s Clean Imei Only Logo
2 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
need unlock code iphone 5c att
  • Cell Phones
