20 Most Recent Samsung VR-325 DVD Recorder / VCR Combo Questions & Answers
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Samsung VR-325... | Answered on Jul 22, 2012
Ok I have been here before. The problem is your DVD burner in your DVD player unit may not be burning the disk in a format recognized by the Computer, or the laser may not have burned the disk to the set standard, and while it can play on that DVD player when you move it to a nother player it will not play. Well what we can do is Test the reverse first. Burn a DVD on your computer and try to play it on your DVD player and on the other TV. Then what I want you to do is to clean the lens of the player and try to burn a disk and play it on your computer. Let me know how this truns out.
Samsung VR-325... | Answered on Jul 24, 2008
check connections if ok possible interference if ok bad board
Samsung... | Answered 16 hours ago
you could do a force back light test .
Remove power cord, remove 1 side of the cable going between the main board and Power board. Plug in power cord and see if you get back light. The light should be on FULL since the main board is removed from the equation.
If backlight is fully bright then it could be the main board causing the problem. Any time you cant see main menu of the TV it also could be main board problem,
If you do force backlight test and the LED still do not look like htey are firing then it could be Power board or LEDs themselves.
Check voltage on CN802 and CNI801, proper low voltage should be listed there
Also CN201 pin 14 should be 1v-4v -> thats the diming signal
Samsung... | Answered Yesterday
The most likely cause is a problem on the power supply take a look at the power supply board if the capacitors are slightly bulged on top they need replaceing
Support - LCD TV LN-T4665F ' Samsung TVs
www.samsung.com > Home > Support
Samsung ElectronicsVisit Samsung today for LN-T4665F. You'll find product and support ... Manuals. UserManual ver.1.0 (EN,ES, 28.06 MB). Apr 26, 2011. Download (pdf)
Samsung... | Answered 3 days ago
Televison & Video Logo
7 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
error 0507
  • Televison & Video
