20 Most Recent
Samsung DVD-P241 DVD Player Questions & Answers
The DVD will not eject - this after a notice comes
Hi.I do not know if you can do it but no other way..Lets try it..
Please got a screwdriver and open the DVD case
from the back. It is simple, just 3 black screws. Then look in
the unit and see how many dvds loaded in the unit. Apparently, some child didn't realize a dvd was already in the loading tray when he loaded another dvd.
if that was the case gently remove the disks by plastic holder open and sliding the disks out.
or sometime the disc was shifts a little from the center. So pls move it to
the center position with fingers so it could be easily rotated
Then put the
cover back on and put the screws back in. Should Work fine now.
I hope this
helps you. I don't think the unit has a manual eject button, but it
sure was easy opening the case and looking in the unit myself. Good
luck.
Please let me know if you need more help.
Regards
DISC IS STUCK AND WON'T EJECT
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Can't open dvd drawer
try putting a Blunt knife into the top of the dvd drawer, or where you can get a knife in.
And gently prise the drawer open whilst pressing eject on the Player.
Failing this, you will have to *****disconnect from the mains***** remove the screws on the rear of the casing, remove the top cover, and take out the DVD Disk.
Replace then plug back in, to check if the player is Ok.
**** Only remove the casing if you feel competant**** And if the player has no guarantee Or Warranty****
Mike @ Compurepair.
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
The disc is stuck and it won't open
Your only real choice is to bring it in for service. You don't want to damage anything by pulling it open, if the disc is really stuck, the player needs to be taken apart to get it out without damaging the dvd player.
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today. I got a screwdriver and opened the case from the back. It was simple, just 3 black screws. Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd. I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out. Then I put the cover back on and put the screws back in. Works fine now. I hope this helps you. I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself. Good luck.
Wont eject dvd
Pull out the power plug leave it out for a while and then put it back in and then hold open/eject button until the DVD player says open/eject let go..the DVD tray should come out.
Please vote if this helps..thankyou!
DVD PLAYER - plays 'red'
had this problem when I start using it with "component" video cables on a new digital wide screen TV. I fixed it through the DVD player's setup menu, by changing the "video output" setting. On my Samsung player there are 3 options: S-video, 525i and 525p. It was set to S-video, and by changing it to any of the other two settings the problem was solved.
