20 Most Recent iLive ISBW2113B BLACK WIRELESS BLUTOOTH SPEAKER STREAM MUSIC Questions & Answers
Can I use only 1 speaker ilive ISBW2113B speaker
Yes, you can use only one iLive ISBW2113B speaker. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker will result in mono sound instead of stereo sound. However, the single speaker will still be functional and able to play audio on its own.
7/16/2023 3:13:37 AM • iLive Audio... • Answered on Jul 16, 2023
Can I use only 1 of my ilive ISBW2113B SPEAKERS
Yes, you can use only one of your iLive ISBW2113B speakers. The iLive ISBW2113B is a Bluetooth speaker that can be used individually or paired with another speaker for stereo sound. If you prefer to use only one speaker, you can connect it to your audio source via Bluetooth or using a wired connection, depending on the available options on the speaker. Keep in mind that using only one speaker may result in mono sound instead of stereo sound.
7/16/2023 3:02:26 AM • iLive Audio... • Answered on Jul 16, 2023
Bought wireless Bluetooth earbuds made by ilive model IAEBT600 v 2559-01 and the right earbud won't pair
If you followed the pairing instructions and they did not paur at the same time, I would have them replaced as they may well be faulty.
6/27/2023 6:35:52 AM • iLive Audio... • Answered on Jun 27, 2023
ILIVE IHT3807DT 2.1 Channel Home Docking System. No sound coming from my iLive speaker system?
Question edited for clarity. Is it plugged in? Have you plugged in something known to work? Have you checked the Fuse? Have you tried the Secret Reset button? https://www.manualslib.com/manual/76114/Ilive-Iht3807dt.html?page=7#manual ..
4/16/2023 10:13:45 PM • iLive Audio... • Answered on Apr 16, 2023
Trouble connecting my 32 HD ILive IT202B sound bar Bluetooth to phone.
Question edited for clarity. I wrote this about Pairing Bluetooth Devices. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices I have just read your iLive manual cover to cover and there is nothing in there to say it is Bluetooth enabled. It isn't in Features and isn't in Set Up. Simply, it won't connect to Bluetooth because it doesn't have that feature. https://www.manualslib.com/manual/700706/Ilive-It202b.html#manual Model 328B appears to be. https://www.google.com/search?q=ilive+it202b+bluetooth+setup ..
4/13/2023 1:56:16 AM • iLive Audio... • Answered on Apr 13, 2023
I have an iLive Model 1KB333S. Need to know how to set the time on a radio please?
Question edited for clarity. The manual at page 2 refers. Setting the Clock 1. With the power off, press the Play/Pause/Memory/Clock button. The hour on the display will begin blinking. 2. Press the Tune buttons to adjust the hour. Press the Play/Pause/Memory/Clock 3. button again to adjust the minutes. The minutes on the display will begin blinking. 4. Press the Tune buttons to adjust the minutes. 5. Press the Play/Pause/Memory/Clock button to finish setting the time https://www.manualslib.com/manual/1052609/Ilive-Ikb333.html?page=2#manual ..
4/2/2023 6:11:58 PM • iLive Audio... • Answered on Apr 02, 2023
2answers
My speaker is static no sound
Pull battery or power cord for 1 minute. Connect and then try connecting to you source again. Bluetooth issue or connecting with 3.5mm cable?? .
8/17/2022 2:07:53 PM • iLive Audio... • Answered on Aug 17, 2022
ILive ISWFV387G replacement battery part number
How to change a battery
12/28/2021 5:26:55 PM • iLive Audio... • Answered on Dec 28, 2021
My ilive platinum speaker lost wifi and the app on my iPhone cannot find it. Also it will not power off. Please Help
Try a reset.
Press the Mode button to manually switch to Aux In mode.
White noise » Power the speaker OFF, then ON again.
Speaker still will not function properly » Hold down the Alexa Mute button for 10 seconds to restore factory settings.
6/7/2019 3:54:59 AM • iLive Audio... • Answered on Jun 07, 2019
Ilive manual user guide ibb377b. no istr. when purchased
iLive has the manual on the product page: https://iliveelectronics.com/speakers/portable/wireless-boombox-ibb377b.html . Click the Downloads button on the left side of the page. The current link to the English version of the manual is file:///F:/Users/Cindy/Downloads/IBB377B-1963-01-English%20User%20Manual.pdf . I hope this helps. Cindy Wells
4/22/2019 12:20:46 AM • iLive Audio... • Answered on Apr 22, 2019
I just received my ilive stereo system from Amazon. The CD won't play. The CD mode shows 2 dashes flashing then goes to upside down U (maybe an n) and an o (?no). Please advise.
contact the seller for a return / refund Sort o thing you can expect from amazon deals
10/9/2018 9:15:25 PM • iLive Audio... • Answered on Oct 09, 2018
How to connect my ilive 5.1 home theatre to my HDMI tv
If the TV and Unit have what's called an ARC socket, then you can purchase an ARC HDMI cable and this will pass both sound and picture between the TV and Audio unit. If it has not, then you will need to connect the sound via either an optical cable or RF cable. Some TV's have only one ARC HDMI socket, so make certain you get the right one!
9/27/2018 10:56:12 PM • iLive Audio... • Answered on Sep 27, 2018
iLive ISBW2113B BLACK WIRELESS BLUTOOTH SPEAKER STREAM MUSIC Logo
1 questions posted
Top iLive Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
 Grubhead
Grubhead
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • iLive Audio Players & Recorders
Most Popular Question
use only 1 ilive isbw2113b speakers
  • Audio Players & Recorders
