20 Most Recent
Unknown HV-800 Wireless Bluetooth Music Stereo Universal Headset Headphone Vibration Neckband Style for iPhone iPad Samsung Purple Questions & Answers
Want to connect it to my PC
well 1st thing ya gotta find out does your pc have a Bluetooth transceiver , this is not the same as wifi ,although sometimes its in same device , after that easy to do it , open Bluetooth property's dialog box ( don't have one you probably don't have blutooth then ) find the find new device box , on the device that you want to connect reset it or an alternative is to open it to " accept " in 30 seconds it takes to establish a connection dialog , wow your done . it s that easy
My bluetooth headset wont charge at all
Check charger. If you don't have another device which might work with this charger, take it to a computer chop, they have tsters to check it. If chager is ok, probably problem is with battery. Sometimes batteries are not user servicable, so you shoud evaluate if it is worth to take your headset to repair shop
Why have my Bluetooth stop pairing with my iPhone 4 it keep saying connection unsuccessful, now discoverable
Hi Timothy
Noise on the same frequency (channel) as your bluetooth connection can inter fear with the connection process.
Check the IOS version you are running. Update if needed via WiFi.
Try outside, away from WIFI & microwave ovens & hotspots & other smart phones & devices in your area.
Turn off your Bluetooth on the iPhone.
Reset the iPhone by quitting all Apps then Hold down Top & Round button together for 5 seconds or more.
Restart your phone with top button (3-4 seconds)
Erase the old bluetooth connection name and restart the discovery routine to establish a new connection.
Last Resort..... Do a full restore or the iPhones IOS
If all else fails.... drop in to your Apple Store
Good Luck
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
