Apparently in some cases all you need to do is start Excel/Word/Powerpoint/Outlook as Administrator in order to get permissions to do something on the computer. If you're using Windows 7, right-click the application in the Start Menu and click "Run as administrator". See if this works for you.
In Windows 8, open the Home screen, find the application you're trying to open; right-click it and select "Open as administrator" at the bottom.
. If you are still experiencing the issue I can suggest this program Excel Repair Toolbox
https://www.repairtoolbox.com/excelrepair.html
If you are in Windows Vista: Go to the top left corner - click the 'Microsoft' button. In the drop down menu - click new ---> new workbook.
If you are running Windows 8.1 ---> go to the file tab (top left corner of your open workbook -->click on new ---> choose the first item - blank workbook.
First locate SCROLL LOCK key in keyboard (Normally it in function keys in laptop, and separate on desktop keyboard).
Now press:-
1. SCROLL LOCK Key
or
2. Fn + SCROLL Lock key (if it is colored as the color of Fn key in laptop)
go google and type in -- user manual for excel--- there are some site that cover the whole manual all 900 odd pages and some sites that deal with specific areas
some are pdf versions so you can down load the section that you want rather then the whole publication
another google search is --libra office cal-search--- which is a free excel user manual, and I found to be better than microsoft excel and it uses the same terms and formula and the whole publication is free
again you can read the publication until you come to the chapter on macro and print out the pages that you want free
worth the read if you are a microsoft person
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Hello Anonymous
Refer to the following video for a complete step by step tutorial on how to create a searchable drop down list in excel. This will work with Excel version 2007 and above
If you need any further assistance, let me know.
Thanks
When you've bought it you were supposed to be given a code (on the CD sticker), if that was done over the Internet rhey're supposed to send you activation through your e-mail.
A small car is easier to handle. A used one that has a few dings so a bump into a post doesn't matter. One with bumpers that stick way out and has the original airbag. Start out in large totally empty parking lots. Sometimes an empty lot with a little snow on the ground can take the seriousness out of it for some learners. Reassure them that the brake is always there and keep your hand ready to pull the emergency brake or turn off the key for them as added reassurance. Remind them that driving is a privilege and that its always best to be predictable. Don't try teaching them on first avenue or Friday night. Perhaps make them fix any damage so they don't make a second mistake. Perhaps try at a simulator in a gamestop...
Sort the data to represent descending order for a chronological data set. If your information is listed in a table format in multiple columns, make sure you select all of the data and sort on the date field.
