20 Most Recent
Samsung SSC-960 VHS VCR Questions & Answers
No picture just sound
Have you tried cleaning the video head with Servisol Video 40? You could use a cleaning tape, but I think it's better to whip off the top and give all surfaces the tape touches a good clean. You can use cotton buds to reach hard to get areas. Leave to dry before trying a tape. This should work as long as it will pick up a normal TV picture. If the VCR does not, this will be waste of time as the tuner unit is faulty.
I would like an owners
Hi.
Here is a link to the pdf version of your manual.
I hope it helps you out, as time lapse vcr's are tricky to begin with, and I really understand why you would want a manual..
http://www.smarthome.com/manuals/7707v96.pdfLike I said, this is a pdf version of the manual, so you can look at it online, or download it if you wish.
Good luck to you, and have a good day !
Will not eject the tape
but you can watch movie and all the functions are working?
if yes, you need to change the drive belt in the system
WE HAVE THE SSC960 SYSTEM AND 3 CAMERAS
I would advise possibly getting a quad to view all 4 cameras. You can also check on the back of the DVR if there is any other place to plug your monitor into. Usually there is a spot port and a monitor port. One will give you the split screen without using a quad. Any camera should work on your system. You would just need to buy a prefabricated cable if you are not familiar with termating BNC connectors. I have a site below that was helpful when installing the cameras at my house. Hope this was helpful.
http://www.123securityproducts.com/
SAMSUNG 960 DATE/TIME WILL NOT ADVANCE
Hi, did you just buy this. Sounds like an error in the mainboard. Take it back and return, nothing you can do to fix it without spending a lot.
Sorry to be the bearer of bad news.
Benjamin
Main menu problem with Samsung SSC-1280
That seems to be SAMSUNG's answer for a lot of their problems. Please to note I have read much too many of their manual. If you didn't catch that - this is the worse written manual I've seen in my 34 yrs. in electronics. My choice is to learn their language, put up with this type of garbage or write this off as a learning experience. I choose to exclude SAMSUNG from my list of considerations for any future equipment purchases.
Tape will not go in all the way.
samsung always gets a faulty door or loading mechanism so if you make any more force to get it load then you will worse the problem, get it to a qualified person to check and change the plastic gear
regards
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
