20 Most Recent Jensen VX7020 6 2 Inch MultiMedia Bluetooth Questions & Answers
0answers
Clock keeps resetting back an hour after I change it. How do I get this to stop?
Check the settings for time zone and DST
4/8/2016 4:46:05 PM • Jensen VX7020 6... • Answered on Apr 08, 2016
Start up volume way too loud! The answer here is to push in volume button to set..my volume button when pushed in sets mute and on/ off
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions http://www.jensenmobile.com/docs/common/VX7020/VX7020_IM.pdf Watch these videoos, maybe get some hint Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver with... Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver Review also some info at this website. Check it: vx7020 manual
6/29/2015 12:55:58 PM • Jensen VX7020 6... • Answered on Jun 29, 2015
I can hear phone but they can't hear me
check the connection of the microphone and if this good if I replace the microphone is integrated in the stereo has to replace the stereo
6/6/2015 3:52:41 AM • Jensen VX7020 6... • Answered on Jun 06, 2015
I have a Jensen JMS7010 marine radio it has water in the face I want to take it apart and dry it out and try to save the radio but it want come apart how can I dry it out or take it apart?
hair dryer if just moisture if water [failed seal or damaged cover ] and need to unscrew ans pry apart --but if water most likely electric circuit damage
4/17/2023 12:21:15 PM • Jensen Car Audio... • Answered on Apr 17, 2023
Wiring diagram Jensen eoa 7p seven band speaker wires.
Your Jenson model as written only appears here on Fixya in your question. The Jenson modelling numbers don't follow what you wrote so your model number 'EOA 7P' is not valid. https://www.google.com/search?q=jensen+eoa+7p ..
4/11/2023 6:17:33 PM • Jensen Car Audio... • Answered on Apr 11, 2023
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
  1. Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
  2. Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
  3. Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
  4. If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
2/24/2023 9:31:14 PM • Jensen Car Audio... • Answered on Feb 24, 2023
Can I use a 270 watt amp kit on a JENSEN 1000 WATT AMP
No, you cannot use a 270 watt amp kit on a 1000 watt amp. The wattage of the amp kit must be equal to or higher than the wattage of the amp it is being used for.
2/22/2023 7:13:10 PM • Jensen Car Audio... • Answered on Feb 22, 2023
I request a schmatic picture
This video may help you https://www.youtube.com/watch?v=VC89DgWJlYw
10/24/2022 1:16:31 PM • Jensen Car Audio... • Answered on Oct 24, 2022
What gauge power wire do I need for my 1200 watt Jensen octane amp
1200 Watts at 12volts is 100 Amps. At least 16mm on a short run.
10/15/2022 12:35:41 PM • Jensen Car Audio... • Answered on Oct 15, 2022
HOW TO SET TIME ON JACOB JENSEN ALARMCLOCK
7/21/2022 2:40:03 PM • Jensen Car Audio... • Answered on Jul 21, 2022
2answers
Jensen CAR1000 brake bypass?
Ground the parking brake wire
3/21/2022 11:29:34 AM • Jensen Car Audio... • Answered on Mar 21, 2022
2answers
I have a Jensen stereo cd/dvd player and when I load a cd or dvd into it constantly is loading and doesn't proceed
I used to own Jensen cd player for a while but I can't remember the solution of loop loading. Check Jensen cd-players manuals http://jensen.manymanuals.com/cd-players
11/21/2020 5:05:18 PM • Jensen Car Audio... • Answered on Nov 21, 2020
Jensen VX7020 6 2 Inch MultiMedia Bluetooth Logo
Popular Tags
10 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
clock keeps resetting back hour after
  • Car Audio & Video
