20 Most Recent
The Neat Company NeatReceipts Scanner & 1-Year NeatCloud Premium Subscription Package Questions & Answers
INIT PS10CC paper shredder
1. Plug in the PS10CC paper shredder to a power source.
2. Make sure the shredder is in the "off" position before plugging it in.
3. Turn on the shredder using the power switch.
4. Insert the paper you want to shred into the designated slot.
5. The shredder will automatically start shredding the paper.
6. If the shredder gets jammed, turn it off and unplug it before attempting to clear the jam.
7. Once you're done shredding, turn off the shredder and unplug it for safety.
Why my Trifo Emma not powering/starting after press button Reset? The robot vacuum is dead.
Some times this is just the charging dock not communicating with the actual robot vacuum. What surface is the charging dock sitting on? It works best if it is on a hard surface and Not carpet.
Try this. Remove the vacuum from the charging dock and turn it completely Off. Unplug the charging dock from the wall outlet. Check inside the charging dock at the connection point the robot plugs into. Make sure it's clean. Next check the robot itself to make sure the connector on that is also clean.
Everything needs to be completely turned off for at least 5 minutes. This does a 'Soft Reset' on the Robot's electronics. After 5 minutes fit the robot back into the charging dock, gently but firmly making sure it is all the way in place. Next plug the charging dock back into the wall outlet. DON'T turn the robot back on. Walk away from it for an hour to let the charging dock put some charge into the battery in the robot. After that hour turn the robot back on and see if the issue has changed.
How to change bulb on the ELMO omnigraphic 252 slide projector
I've included a video tutorial at the end of these instructions. To change the bulb on your ELMO Omnigraphic 252 slide projector, follow these steps:
Safety First: Unplug the projector from the power source and allow it to cool down for at least an hour. This ensures your safety and prevents accidental burns.
Locate the Lamp Access Panel: Look for the lamp access panel on your projector. It's usually located near the lens or on the side of the projector body.
Remove the Screws and Access Panel: Use a screwdriver to remove any screws securing the access panel. Once removed, you'll have access to the lamp housing.
Remove the Lamp Housing: Reach inside the projector and firmly pull out the lamp housing. It might be held in place by additional screws; remove those as well.
Replace the Bulb: Take out the old bulb (lamp module) from the housing. Make sure you have a compatible replacement bulb. Handle the new bulb carefully to avoid touching the glass surface.
Insert the New Bulb: Slide the new bulb into the housing, aligning it properly. Secure it in place with any screws that were removed earlier.
Reset the Lamp Hours: If your projector has a lamp hour counter, reset it to zero. Refer to your projector's manual for instructions on how to do this.
Close Up: Put the lamp housing back into the projector, replace the access panel, and tighten the screws.
Remember to consult your ELMO Omnigraphic 252 user manual for specific details related to your projector model.
How to Change a Projector Lamp (youtube.com)
Where can i find the replacement for a
CA 27 VIZIO AIO COMPUTER SUBWOOFE R POWER SUPPLY
- Contact VIZIO Support: Start by reaching out to VIZIO's customer support. They may be able to provide information on where to purchase replacement parts or direct you to an authorized service center.
- Check VIZIO's Official Website: Visit the official VIZIO website and navigate to the support or accessories section. Some manufacturers sell replacement parts directly through their websites.
- Search Online Retailers: Check popular online retailers such as Amazon, eBay, or electronics parts stores. Use specific keywords like "VIZIO AIO computer subwoofer power supply" to narrow down your search.
- Electronics Parts Stores: Visit local or online electronics parts stores. They often carry a variety of power supplies, and you may find one that matches the specifications of your VIZIO AIO computer subwoofer.
- Specialized Electronic Repair Shops: Local electronic repair shops or service centers may have access to a variety of replacement parts. Contact them to inquire about the availability of a compatible power supply for your VIZIO AIO computer subwoofer.
- Check Compatibility: Ensure that the replacement power supply meets the necessary specifications for your VIZIO AIO computer subwoofer. Look for details such as voltage, current, and connector type to ensure compatibility.
If there is papers on the tray. but still displaying "Add paper" what can i do
According to the technical manual, the "Add paper" error message may appear if the safety switch over or under the paper feed tray is activated. You can cancel this error by pressing the safety switch and removing any obstacles. You can also check the paper feed area for any paper jams or misfeeds and remove them carefully.
If the error persists, you may need to contact a certified dealer or service technician for further assistance.
