20 Most Recent
The Neat Company NeatDesk Scanner & 1-Year NeatCloud Premium Subscription Package Questions & Answers
My register is only printing on half paper
Assuming you have the correct thermal paper in the register, here is something to try:
The SPS-320 has an electronic journal that can be printed to memory rather than live on paper.
To print the journal entries, follow these steps:
Turn off the register.
Hold down the "Journal" button (usually located on the keyboard).
While holding the button, turn the register back on.
Release the button. The journal entries should now print.
Check for Errors:
Review the register's display for any error messages or codes.
If there are error messages, consult the user manual or seek professional assistance.
Contact Support:
If the issue persists, consider reaching out to Sam4S customer support .
INIT PS10CC paper shredder
Does it have an 'Automatic' Setting? If it does, the issue will be the small lever or IR Sensor that senses paper in the throat to the shredder and turns it on. If it doesn't, the problem will be the switch, or the contacts to the switch. The fact it runs in reverse proves that the motor is fine.
It appears to be a budget end shredder sold at Best Buy, eBay and Amazon so getting spares might prove difficult.
Why my Trifo Emma not powering/starting after press button Reset? The robot vacuum is dead.
Some times this is just the charging dock not communicating with the actual robot vacuum. What surface is the charging dock sitting on? It works best if it is on a hard surface and Not carpet.
Try this. Remove the vacuum from the charging dock and turn it completely Off. Unplug the charging dock from the wall outlet. Check inside the charging dock at the connection point the robot plugs into. Make sure it's clean. Next check the robot itself to make sure the connector on that is also clean.
Everything needs to be completely turned off for at least 5 minutes. This does a 'Soft Reset' on the Robot's electronics. After 5 minutes fit the robot back into the charging dock, gently but firmly making sure it is all the way in place. Next plug the charging dock back into the wall outlet. DON'T turn the robot back on. Walk away from it for an hour to let the charging dock put some charge into the battery in the robot. After that hour turn the robot back on and see if the issue has changed.
