20 Most Recent
Blu Dash Jr 4.0 K Cell Phone Questions & Answers
How do i reset a blu dash jr 4.0 k phone? model part is D142k
There should be an option to reset your phone in 'settings'.
Back Up and Reset should give you the option to reset with no problems. As you enter this option, the last option here is 'Factory Data Reset'. Try this and let me know what transpired after....
How do I reset the blu dash jr 4.ok
press the home key, volume key, and power key hold for 10-15 seconds, when screen changes only release power key and continue holding volume key and home key. A menu will appear on your screen just follow instructions to do a reset. Good luck
Have Blu View 3 that can't make or receive calls, can you please help me?
I remember reading somewhere about an issue with so called off brand phones(Non-Flagship)... as im in the same boat(Using Cubot Brand) and talking with my service provider today. they stated my phone isnt on the list or compatable with the at&t network anymore(atleast the calling part of it) you should still be able to use data & text. Lucky i already have a third party app for a 2nd phone and also use google voice, both of which let me make calls using my data. and if i need to contact someone i can either send a voice/text message as normal.I have read somewhere that i believe blu is trying to get onto the att network. So hopefully they do because ill just switch back sense they are a good phone company. Hope this info helps.:Edit: Even if it is 4g LTE, also spoke with a friend who has a 5g non-flagship whos carrier uses att and she isnt able to make calls from the phone but the speeds are still there. So hopefully something gets fixed because I believe this is some B.S. to lock us out because we dont want to pay for a iphone or samsung
How do i block a number? BLU advance 5.0
1. Touch the icon that says "Phone" on your main screen.
2. Click on the entry for the number you want to block under "logs."
3. Press the menu button on your BLU advance 5.0.
4. Select add to "reject list."
How can I retrieve deleted text messages
heHello,
Two ways you can get back yourdeleted messages from the phone.
1)From the service provider.
WHAT YOU NEDD TO DO TO GET BACK THE MESSAGE FROM THEM IS TO CALL ON THEM
FROM THE CUSMER CARE CENTER.
2)From the other side that the message was send from. Thanks.
Why when I hit contacts google pops up first
Googled Blu phone. Blu phone is an android device. Android is another name for google. Specifically android is googles operating system. If you were looking for another contact list you will have to download an app and set that up. But on this part you are on your own for now. I an an Android user and like it that way.
Hope this helps.
How do I make my BLU vivo picture gallery visible on a windows computer so I can transfer pictures from phone to PC?
With a USB cable connected from phone to PC, Windows explorer should detect it as a 'Mass Storage Device'.
This should also show up in 'My Computer' as a virtual drive.
If not, you may need to first install BLU driver for your phone.
Once set up correctly, you can configure the device's 'Auto-Load' function to automatically download media from the phone when USB is plugged in.
Otherwise you can navigate via the 'My Computer' screen to explore files on the virtual drive.
