20 Most Recent Samsung HCL5515W 55" Rear Projection Television Questions & Answers
go into settings and check audio if set on TV sound or Audio system also there can be issues with HD channels and regulars channels I hope this helps
Samsung HCL5515W... | Answered on Aug 22, 2014
Adjustment or IC replacement---the adjustment with the original remote via the customer menu should be tried first----set if has convergence should use either two stk-392-040 or -020 chips that are interchangeable with the -040 being the higher current part and more expensive.
Samsung HCL5515W... | Answered on Oct 26, 2012
If it is a bad virus that won't let you do anything on the computer, follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
To remove the old antivirus, go into Control Panel, Add Remove Programs (or Programs and Features for newer Windows) and double click on the antivirus to start the uninstall process.
Samsung HCL5515W... | Answered on Jan 06, 2011
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingnmets,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.U have some machanicals skills?Can u take things aparts and putting it back together again?Yes,than try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The DLP Tvs Akai/Samsung models used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Samsung HCL5515W... | Answered on Nov 18, 2010
if you still have the service manual can you email it to me april1371@wildblue.net red convergence went out thanks
Samsung HCL5515W... | Answered on Jun 23, 2010
maybe theres other parts is opened causing to blow up the capacitor. the best is to have to repair your tv to the qualified technician coming from samsung service centers in your area. that problem is easy for them.
Samsung HCL5515W... | Answered on Jun 19, 2010
I am having the same issue. In fact there was a burning smell.
Most likely the capacitor blew.
Will post if I find the part number.
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Samsung HCL5515W... | Answered on Jun 16, 2010
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Samsung HCL5515W... | Answered on May 30, 2010
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Samsung HCL5515W... | Answered on Apr 22, 2010
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can hire a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a step by step picture instruction guide, original OEM parts, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Samsung HCL5515W... | Answered on Mar 12, 2010
Bad Color Wheel 1-800-638-3328
Samsung HCL5515W... | Answered on Jan 03, 2010
Did you check the Resistors or replace any resistors (3.9 ohm Ibelieve)? If not look there first. Did you replace both IC's and what were the symptoms b4 you replaced them. By "covergence appeared then quickly left" do you mean the convergence was all good and then it went out again? Too much missing info reply to this or post again with more info and try to help.
Samsung HCL5515W... | Answered on Oct 06, 2009
Hi Stile,
Do you hear any clickimg? If you do, it could be your ballast and if your TV is 3 to 4 years old then you want to replace your lamp,you can get good price and advise with the guys at DM http://www.discount-merchant.com/?CLICK=52978
please keep us posted
Samsung HCL5515W... | Answered on Oct 05, 2009
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Samsung HCL5515W... | Answered on Aug 07, 2009
Samsung HCL5515W 55" Rear Projection Television Logo
Popular Tags
56 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
adjust focus lenses hcl5515w
  • Televison & Video
