20 Most Recent Air Conditioning and Heat for Chevrolet Cruze Questions & Answers
2011 CHEVY CRUZE AC
What is your question about?
11/25/2018 2:22:41 AM • Air Conditioning... • Answered on Nov 25, 2018
2answers
Conditioner not blowing cold air continuosily at high speed
Which year/model/make of car is the problem with
1/2/2017 10:38:06 AM • Air Conditioning... • Answered on Jan 02, 2017
Heat blows cold air 2012 chevy cruze
Thermostat is bad and they fail in the 'open' position so the water will circulate and not over heat the engine as id it failed in the 'closed' position. Thus, the water never gets warm enough for the heater core to blow hot air
1/25/2015 2:39:17 PM • Air Conditioning... • Answered on Jan 25, 2015
2012 chey cruz a/c blowing hot on driver side
the blend door needs replaced--remove dash to get to it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
10/8/2014 10:49:09 PM • Air Conditioning... • Answered on Oct 08, 2014
Air condition button does nothing on 2011 chevy cruze
Means that there is a fault in the hvac system most of the time. You should have the car scanned for any codes in body control module
8/25/2014 12:54:05 AM • Air Conditioning... • Answered on Aug 25, 2014
2answers
My AC isn't working at all. Hot air comes out of vents along with a funny noise from the hood. What could be the problem? The compressor?
Take your car to the dealership, it should still be under warranty. Do not let any uncertified mechanic touch it, or you will loose your warranty. If you have no warranty, yes, it is your A/C pump. First get it charged to see if it still works. If it does not work, replace the pump.( You do not want to pay to replace the pump unless you have some good money)
5/29/2014 2:22:09 PM • Air Conditioning... • Answered on May 29, 2014
Passengers side no heating
Either a bad accuator not opening the pass side door under the dash or a bad control unit itself probably not a vacuum leak I really think the 1 st one accuator thanx
3/2/2014 5:09:17 AM • Air Conditioning... • Answered on Mar 02, 2014
My 2011 Cruze heater is blowing cold air and the car overheats.
Check water level and for radiator leaks
12/25/2013 10:54:41 PM • Air Conditioning... • Answered on Dec 25, 2013
My aircon weakend
Possibly needs to be recharged or checked for leaks by a qualified Air con service agent.
10/11/2013 8:49:56 PM • Air Conditioning... • Answered on Oct 11, 2013
My 2011 Cruze"s power to
Even if the problem is as simple as a fuse, fuses don't blow without there being an electrical problem. Take the car to the dealer to be fixed under warranty. Don't attempt any repair yourself or you may void the warranty.
3/7/2011 11:08:52 PM • Air Conditioning... • Answered on Mar 07, 2011
Brandnew car... battery sign lights on... after 20
Slightly high voltage output of the altenator. Usually should be between 13.8 to 14.2 Volts. Not a good start for you.
3/7/2011 12:20:27 PM • Air Conditioning... • Answered on Mar 07, 2011
2answers
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM • Chevrolet... • Answered on Sep 09, 2022
Drum brakes 1998 s10
What is the question?
11/25/2018 2:32:16 AM • Chevrolet... • Answered on Nov 25, 2018
Torque specs 05 Chevy Silverado 1500 4WD front hub assy and axle nut
165 ft lbs
11/25/2018 2:26:57 AM • Chevrolet... • Answered on Nov 25, 2018
I tried the solution for the ast ultra remote car
It is still immobilized through the alarm system then.
8/29/2017 6:20:45 AM • Chevrolet... • Answered on Aug 29, 2017
4answers
Check engine light on says p2000 on code reader
The code is: P2000 NOx Trap Efficiency Below Threshold Bank1 and I do not know what that is unless it has something to do with the oxygen supply to the engine. Sorry I am not much help.
10/30/2015 6:24:22 PM • Chevrolet... • Answered on Oct 30, 2015
Shuts off while driving and looses all lights
sounds like the alternator is not putting out. If you start the car and remove the battery cable and the engine shuts off then the alternator is bad and you need to change it.
10/4/2015 7:09:19 AM • Chevrolet... • Answered on Oct 04, 2015
Air Conditioning and Heat for Chevrolet Cruze Logo
11 questions posted
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Vehicle Parts & Accessories
Most Popular Question
ac isn 39 t working all hot air comes
  • Vehicle Parts & Accessories
