20 Most Recent Cavs CDO-98E Questions & Answers
YOUR GUESS MIGHT BE BETTER THAN OURS . WE DO NOT KNOW WHERE YOU ARE AND REALLY DO NOT CARE
Cavs Televison &... | Answered on Dec 11, 2018
What is the brand name and type of the TV? Without these details, how can one post a solution to your problem? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Televison &... | Answered 9 minutes ago
OK. Could you please tell us the make and model, and what you have tried so far? Otherwise it is very difficult to help
First of all, have you plugged it into a different AC outlet?
Have you tried using the button on the screen itself as well as the remote control? Have you tried changing batteries in the remote? When you say you can't get it on, do you mean there are no lights at all that turn on when you use the switch, or that there are some lights and or the screen starts glowing, but you get a blank screen?
Televison &... | Answered 53 minutes ago
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Televison &... | Answered 1 hour ago
Hi , my original remote control for Supra TV(ST29k22b) is broken .
I have a universal remote (Olympia - URC-22B25).
Can someone pls explain how to sync this new remote to my TV.
Also for some reason i cannot see the full pictire on the TV, all the edges of the pictures are like cut off or merged inside the TV.
Televison &... | Answered 3 hours ago
DOUBTFUL TAKES SOME SPECIAL TESTING EQUIPMENT
Televison &... | Answered 7 hours ago
Is it possible this is your machine?
chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/http://pdfstream.manualsonline.com/a/aca7af7e-c8b5-4b10-9296-41863f922391.pdf
Televison &... | Answered 12 hours ago
The 8-hour limitation is probably a safety design to keep your heater from overheating. Get another heater with a longer program capability, or plugin a second heater when the first one shuts down.
Televison &... | Answered 13 hours ago
Would help immensely if you would tell us what device you are using and/or what software you are running.
Televison &... | Answered 14 hours ago
see the steps and fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours
Televison &... | Answered 16 hours ago
Have you made sure the disks are clean and have no marring on them? Blue Ray players are very sensitive to any disk issues. Also have you checked to see if any updated Firmware (the software the system uses to read the movies) has been released for the player? They constantly update the operating software of players and the way the disks are recorded, so regular updating is essential to prevent this type of problem in playback, freeze up is the most common complaint.
Televison &... | Answered 17 hours ago
Hooking up an old VCR is a doddle if you also have an old analogue tv.
The VCR provides an analogue output via a scart socket, often via phono sockets (2 or 3) or by rf modulation, providing an output into the aerial socket of the tv that could be tuned-in like a regular analogue tv station.
If the tv has a scart socket it should be plug and play, even with a digital tv, otherwise you will need an analogue to digital converter, probably the most economic types are the popular VHS grabber types designed to convert the VHS output into a format a computer can burn onto a dvd but many others are available in many different price bands.
Televison &... | Answered 18 hours ago
Sounds like the TV doesnt recognize the Firestick as an HDMI source. Or the Firestick isn't getting power. Or the Firestick is broken.
Does the firestick work in the HDMI port the DirectTV is currently in?
Televison &... | Answered 22 hours ago
Cavs CDO-98E Logo
3 questions posted
Top Cavs Televison & Video Experts
Marvin
Marvin
Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cavs Televison & Video
Most Popular Question
cavs dvd 202g karaokee player displays
  • Televison & Video
