20 Most Recent
Gaskets for Ford Laser Questions & Answers
Car engine temparature always show
Sounds like you need to replace thermostat. Thermostats open and close accordingly to engine temps. When reading goes hi usually indicates thermostat is sticking open, recirculating hot coolant. Now you mentioned it's been reading normal which makes me think this thermostat is not working consistent. So I'd change it now before it overheats and causes alot of damage. Regarding hot water in radiator, after running any time it's going to be hot, normal engine temp is around 195 degrees.
Diesel Pump Rotor Head 1 468 334 337
diesel Pump Rotor Head 1 468 334 337
Item Name(EH)#injector bmw 320d e46#
# head rotor ford 12 mm#
#head rotor ford 187l#
#injector chrysler voyager#
#for injector common rail delphi#
#Ultrasonic Injector Cleaning Machine
#UltraSonic Fuel Injector Cleaning
(EH)China Lutong Parts Plant is a famous manufacturer and supplier specializing in diesel engine parts.We have 30 years experience in this area.
Our aim and business policy is to give the customer a reliable quality product and service, alternative to the OE products. The parts are quality
assured to ISO9001 and are subject to regular internal and external audits ensuring that quality is the highest standard.
nicole(at)china-lutong (dot) net
Wha/tsa/pp:+86133/8690/1375
[email protected]
I have a 1996 ford windstar
They remote is for the immobiliser system. Immobilisers are designed to be VERY difficult to bypass otherwise why fit them? Your simplest solution here is to go to a car key specialist and get a new remote. Once the old one fails the car will not start at all.
Just replace a Ford Falcon AU radio with a
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Im having a problem with my remote start. It goes on , but shuts off in 15 seconds. I have a Ford Explorer with a viper alarm.
Just a guess, since some disengage if signal not getting thru that motor running, to prevent starter brushes overheating, burning, etc, and you say motor starts, maybe a dirty electrical connection, like oil or something got in somewhere, interfering with that signal being received. To rule that out I guess yourself or shop, have all electrical connectors looked at for oil, dirt, oxidation, loose, etc... Simply pulling connectors and pushing back on few times might do it if that the issue. Notice if it feels tight or not. If oily dirty, maybe spray male and female parts of connector with alcohol based spray degreaser. Silicone spray has fast evaporating alcohol but the silicone may interfere with electrical connection. Also, be sure your remote button not triggered by weak spring contacting when you set it down or put in pocket as that'll act to shut off if already on. I had 1 get like that. Would park car, head in, putting remote in pocket after going in, would notice car running from inside.
Where is the fuse for the rear window defroster for a 2003 ford windstar
The fuse panel is below and to the left of the steering wheel by the brake pedal. Remove the cover to access fuse panel. There should be a fuse puller tool fastened to the fuse panel cover. check the fuse in position number 10(it should be a 10 amp fuse). Also check relay number 5 which is the Rear Defrost Relay. If both the fuse and Relay are good, check under the hood for the power distribution box. Locate it, disconnect the battery, open the power distribution box, check fuse number 121 (it should be a 20 amp fuse). Check also fuse number 116(it should be a 30 amp fuse). Replace the faulty one(s) and then close the Power Distribution Box. Reconnect the battery. Hope this helps! Blessings!
