20 Most Recent
Nokia Lumia 1320 Smartphone - RM-995 Questions & Answers
Screen font too big lumia 1320
Try turning the phone off then after reboot navigate to the settings go to ease of access then reset the text by sliding on the bar
Hope this helped
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
