20 Most Recent Lexar 16GB JUMPDRIVE S33 USB 3.0 TEAL Questions & Answers
The chip inside that is used to store information went bad. There is no way to recover the drive.
Lexar 16GB... | Answered on Oct 18, 2015
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
what email program do you use and have you tried to access your e-mails from another machine.
If you can access your e-mails , I would suggest that you only open/view TRUSTED senders and those without attachments as you may have picked up a virus when opening/viewing messages.
Do you have any anti virus / malware checkers ?
Have you run them ?
Please try and give more information as this may allow more forum members to assist / guide you.
Computers &... | Answered 54 minutes ago
this is a repair website. we have nothing on tax numbers here
Computers &... | Answered 1 hour ago
try plugging into a different USB port. Did it ever work on this laptop?
If it's the first time your using it on this laptop you may need to install the correct driver for the dvd drive, if your using Windows 10 then you should be able to automatically download the drive via the device manager on windows if you have any probs just go to the website for the device manufacturer and download the correct driver for that model (make sure it's the correct one) and follow their instructions for installation then reboot PC and try re-connecting.
DOES NOT MATTER TO US THIS IS A REPAIR FORUM ONLY TRY THE RIGHT WEBSITE ONCE
Computers &... | Answered 2 hours ago
The meaning of BIOS (basic input/output system) BIOS software has a number of different roles, but its most important role is to load the operating system.
Computers &... | Answered 4 hours ago
ENGLISH PLEASE.
Computers &... | Answered 5 hours ago
Why does iTunes Duplicate Songs When Importing The issue that iTunes duplicates songs when importing is quite common and many users are not clear on the reasons for it. In order to clear up this confusion for iTunes users, here are some main causes of this trouble.
1. When you find your iTunes duplicates songs when importing to the library, it may result from improper settings of your program. You may have checked the options of "Keep iTunes media folder organized" and "Copy files to iTunes Media folder when adding to library". Thus, iTunes will repeatedly import a folder that is outside that iTunes Media folder into the library.
2. If the folder you add to iTunes library already has several duplicated songs, iTunes will import in all of them. Thus, you will find them duplicated in iTunes library.
3. If the songs you add to iTunes are untagged, iTunes will organize them all into "Unknown Artist/Unknown Album" and set the music name to "Filename". You will be unable to identify the song you need, for their name are almost the same.
4. iTunes does not have the feature to monitor your media folders when you import songs to the library. It just has trouble in detecting what is already on the library. This is one disadvantage of using iTunes itself to import songs.
Remove Duplicates after Importing with iTunes
Apart from avoiding duplicates before and in the process of importing, you can also use iTunes to remove duplicates after the importing. This aim can be achieved simply with the following steps.
1. Run iTunes on your computer and then click on "File" menu in the toolbar. Then you need to hit on "Library> Show Duplicate Items" in order.
2. You will see a list of all duplicates displayed in the right part of the iTunes screen. You can then click on a track or hold down the "Ctrl" key while hitting on multiple tracks to choose them.
3. When you have selected the items, you can click on "Song> Delete from Library" to remove the songs you have selected. The duplicated songs will disappear immediately from the iTunes interface. Thus, your iTunes library will be much clearer.
You should know that iTunes sometimes can confuse different mixes and slight variations shown in different albums. Therefore, you'd better make sure what you are removing is actually a duplicated and not a remix or version from a different album.
how-to-import-songs-into-itunes-without-creating-duplicates-delete-6-1srvjsc4otpwize3cqbthuvm-1-0.jpg For more details, check: Why does iTunes Duplicate Songs When Importing
Computers &... | Answered 7 hours ago
NO DRIVERS WERE MADE FOR IT .
Computers &... | Answered 8 hours ago
Lexar 16GB JUMPDRIVE S33 USB 3.0 TEAL Logo
1 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
Dayton Computer
Dayton Computer
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
drive not detecting in pc or others
  • Computers & Internet
