20 Most Recent Hisense 40" Smart TV Full HD 1080p LED HDTV with Built in WiFi - 40K20D Questions & Answers
Does your TV have RJ45 connector ?
That looks like
26263581-kbmxcsgdcjwkxkxfv11waner-3-0.png Insert a RJ45 patch cable from the router to that port using taht looks like this
26263581-kbmxcsgdcjwkxkxfv11waner-3-2.png Your TV should AUTOMATICALLY now be on the network
Hisense 40"... | Answered on Sep 06, 2016
Ok what kind of tv do you have? I need the make model ? And what kind of remote do you have?
Hisense 40"... | Answered on Apr 30, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the ‘device’s brand name list’ in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Hisense 40"... | Answered on Apr 07, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
That depends on the type of antenna, but in general it attaches to the same jack as your cable would. On the tv setup menu there witll be an option for cable or antenna, and then you'll need to run a scan to setup the channels. If the antenna you chose doen't have a ***** on connetor like cable, you can get an adapter at Radio Shack.
Hisense 40"... | Answered on Mar 28, 2016
Hi Laz
Televisions get power supply unit problems that do exacly what your describing.
It is Caused by ageing Electrolytic Capacitors.
If your not tech savvy then take it to a technician
otherwise
Find & Replace the Caps yourself
Try These
Switched mode power supply
How to Replace an Electrolytic Capacitor
Good Luck
Hisense 40"... | Answered on Mar 14, 2016
I had the same problem right up until the HDMI stopped working altogether. I had to use the ''component'' cables instead. The problem in my case is a bad HDMI socket (circuit board). The word ''randomly'' caught my attention. That's exactly how it happened with mine.
Hisense 40"... | Answered on Jan 02, 2015
If you wish to get some details; check the site linked here. Pull up older posts...
Hisense... | Answered 8 hours ago
Hello Ginnie, it may be that your remote control has the VOL-locked button and produces the fault, to test the batteries to the remote control and check if it continues to do so.
Another option may be that the VOL- control, on the TV, is locked or has some internal dirt and generates a false contact that could cause the failure
Check these points to see if you have problem solution
If not consult a specialized technical service
I hope I can solve the problem
Greetings Franco Dosil
Hola Ginnie, puede ser que su control remoto, tenga el bot?n de VOL- trabado y produzca la falla, para probar saque las pilas al control remoto y compruebe si lo sigue haciendo
Otra opci?n puede ser que el control de VOL- , en el televisor, se encuentre trabado o tenga alguna suciedad interna y genere como un falso contacto que pueda provocar la falla
Compruebe estos puntos a ver si tiene soluci?n del problema
Sino consulte a un servicio t?cnico especializado
Espero pueda resolver el problema
Saludos Franco Dosil
Hisense... | Answered 2 days ago
SOUND SETTINGS PERHAPS
Hisense... | Answered 3 days ago
you can use channels change button or if it's a smart tv you get mouse button let me know i will help you just sent me email me at gsm.mohsan@gmail.com or whattsapp 00276097665
Hisense... | Answered on May 16, 2019
The power supply may be failing, recovering, then failing again.
Hisense... | Answered on May 15, 2019
Hisense 40&quot Smart TV Full HD 1080p LED HDTV with Built in WiFi - 40K20D Logo
11 questions posted
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
need help connect network hisense smart
  • Televison & Video
