20 Most Recent
LG Isai LGL22 3G Unlocked Phone 32GB SIM Free Questions & Answers
When i make a call i can hear the person but they can't hear me.
if the phone is old or has been dropped then it could be your mic that has broke. the speaker is at the top ( so you can hear ) mic is at the bottom ( so they can hear ) but if you know the phone is fine or was fine then you could of muted the call. dial out and keep the phone away from your ear so you can check the screen ( the screen turns off when you hold it to your ear ) then you can check for a mute button or secrecy button. ( we use them to put people on hold so they cant hear what we say )
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
