20 Most Recent
Samsung HT-DS610 System Questions & Answers
Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
- Turn on your Home
Theater System.
- Press the Stop button
on the front panel and
the Power button on the
remote control simultaneously
for four seconds.
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
- Turn on your Home
Theater System.
- Press and hold the
Function button on the
front panel for 3 seconds.
The display shows the
word Unlock.
Note: Repeating
Unlocking Procedure 3
steps
- Turn on your Home
Theater System.
Open/Close button on the
DVD player on the front
panel for more than 4
seconds.
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
- Using the HTS remote press the Menu button + 712, and the HTS will display
CAN OPEN.
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
Why wont any of my disc load?
Available from Partsmaster for about 70 quid
Panasonic SAHT870 DVD Mechanism Assy
Panasonic DVD, Video, Home Cinema SAHT870
Samsung dvd/disc protection
Try a hard reset: unplug from power source, remove all cabling and wait for 5 minutes before recabling.
If that fails, it is a logic board error, in which case you are probably better off buying a new device..
Samsung HT-DS610
Will not stay on.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
I have a ht-ds610 and
Hi, in the case, you might not be able to indicate if really a fault or an indicator to protect the system from getting damaged.
I would advice if you have the manual for the system, you could use it to troubleshoot it to find out if it's a fault or a protection for the system.
You could also contact a skillful repair man to check troubleshoot andtellyou the part that is faulty and that will need to be replaced.
Hope that would. You can pass on your comment.
Thanks for using fixya.......
