20 Most Recent Android LG Optimus Dynamic II LG39C Smartphone fo Questions & Answers
2answers
Why do I get "message expired" when I try to open a picture sent to my phone?
Some phones only hold pics in msgs for a limited amount of time. Next time you recieve a pic msgs tap and hold to bring up the menu on it. The save image. It will download to your gallery. Problem solved
6/25/2022 7:02:32 PM • Android LG... • Answered on Jun 25, 2022
I need help resetting APN, Proxy etc.
Go To Setting - Mobile Network- Access Point Names- Click Option Touch And Create New APN
9/5/2016 6:21:53 AM • Android LG... • Answered on Sep 05, 2016
How do I get into my lg phone when I forgot my pin/password
The only way to get back into your device is to do a factory reset. Keep in mind, Google has an activation lock to prevent theft of your device. With that being said, after you factory reset your phone it may ask you to login to the original gmail account that your device was set up with. To do a factory reset, you need to boot the phone into recovery mode:
  1. Power down the device
  2. Hold down the following keys: Volume Up + Home + Power or Volume Up + Home + Search
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
2/23/2016 6:17:29 AM • Android LG... • Answered on Feb 23, 2016
Screen goes black after making call which means I can't punch in extension
Sounds like the proximity sensor. The phone has a sensor that attempts to determine if the phone is up to your ear, and then shuts the screen when it is to save battery. However, if you have a screen protector of any sort it can block the sensor, making the phone think it is up to your ear once you place the call. Easiest way to test this is to disable the proximity sensor then place a call. If the screen does not instantly go black after you place the call, then you know for sure something is blocking it. If you have a screen protector, try removing that. To disable the sensor:
  1. Goto settings
  2. Call settings
  3. Additional settings
  4. Uncheck the proximity sensor box
2/23/2016 5:23:42 AM • Android LG... • Answered on Feb 23, 2016
How do I remove battery to do soft reset?
hold volume down and power button to enter reset mode
1/19/2016 2:40:38 AM • Android LG... • Answered on Jan 19, 2016
How do I open browser on LG cell phone?
Find its icon and tap it.
12/1/2015 7:54:16 AM • Android LG... • Answered on Dec 01, 2015
TRIED TO ANSWER TEXT, GOT BACK INSUFFIENT FUNDS
you already got the problem there. Insufficient funds. that means you doesn't have enough balance to send text message. But if you sure you have enough then contact your network provider and complain to them because it will be their error not the phone
7/31/2015 4:44:51 AM • Android LG... • Answered on Jul 31, 2015
Will my LG Optimus call 911
Yes you can call 911 with this phone (andriod optimus dynamic 2 LG36C smartphone. You can either go to the unlock screen and click emergency call or you could go to the dialing screen and dial 911. I Hope this was help to you!!
5/25/2015 12:59:47 AM • Android LG... • Answered on May 25, 2015
Transferring memory from phone memory to installed sd card
you can not transfer the apps that are installed as they have been installed into the phones memory ? you can download the full app onto the card then install onto the phone. ( when an app is installed into the phone it needs "bits" of the phones software to run so its "sort of " all in small parts scattered all over the phones memory ) a downloaded app is a complete all in one program,it only gets sent all over when installed... only way to save room is to "uninstall" some apps
5/8/2015 8:30:38 PM • Android LG... • Answered on May 08, 2015
How to get out of emergency call, frozen and no icons or menus
try a reboot or restore both options are in the following menu. turn off phone. press and hold the volume up button and the home button ( on the front ) now with a spare finger turn the power on ( keep holding the 2 buttons ) you should see the green android then a menu. if you dont see it then turn off and try again. only leave go of the buttons when you see the little green android man
5/1/2015 3:50:27 PM • Android LG... • Answered on May 01, 2015
0answers
I need to know, how do you use speed dial ?
you can use speed dial to call some selected numbers you personally choose to call. it is fast to call the phone number just by long pressing a key from you keyboard.. Moreover, you can use keys from 2-9 one your keypad but 1, is reserved for voice number.
4/6/2015 11:58:08 PM • Android LG... • Answered on Apr 06, 2015
IN MY LG39C HOW DO I GET THE PICTURES FROM THE PHOTO GALLERY ALBUM TO THE PICTURES ALBUM SO I CAN PUT DOWNLOAD THEM MY PC?
Open the photo gallery album and select a photo, tap the "menu" key, then tap "move", and select destination.
2/18/2015 10:48:19 PM • Android LG... • Answered on Feb 18, 2015
I just got an Lg optimus dynamic 11 a few days ago and now the screen has been frozen for hours I cant unlock it or anything but my buttons work, how do i fix it
Take your phone to your local mobile phone shop they will unlock your phone for about £15.
2/17/2015 6:05:29 PM • Android LG... • Answered on Feb 17, 2015
The link to how many minutes I have left does not work.
There are a couple of ways to see your minutes. One would be if you go to your settings then go to your phone or account info. Then it will show you what your minutes are.
11/11/2014 6:16:09 PM • Android LG... • Answered on Nov 11, 2014
Keep getting "message expired"
Some providers and or phones have a time limit on the pics sent via txt or mms. Unfortunately idk if you can recover your past pics. But the next time you recieve a pic this way, try tapping and holding the image to bring up the options menu. Then select save image or download image. This will save the image to your gallery.
11/7/2014 5:47:28 PM • Android LG... • Answered on Nov 07, 2014
How do i set up an account for my new phone?
You will need to visit Google.com or contact your cellular phone service provider.
10/15/2014 2:38:17 PM • Android LG... • Answered on Oct 15, 2014
How do I add Verizon to my smart phone. Just purchased an LG Optimus Dynamic II phone through Tracfone. Verizon is my internet provider for home and office.
Sorry to tell you, Verizon strictly forbids adding non-Verizon Wireless phones on their network. You're stuck with Tracphone or other GSM pay-as-you-go providers.
9/25/2014 1:56:48 AM • Android LG... • Answered on Sep 25, 2014
2answers
Photo editing app suggestion
The word 'Best' is too subjective for an anwer.
4/3/2024 1:52:08 AM • Android Cell... • Answered on Apr 03, 2024
Android LG Optimus Dynamic II LG39C Smartphone fo Logo
Popular Tags
22 questions posted
Top Android Cell Phones Experts
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Steve Sweetleaf
Steve Sweetleaf
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Android Cell Phones
  • Android Cell Phones
Most Popular Question
get out emergency call frozen no icons
  • Cell Phones
