20 Most Recent
SanDisk SDMX1 MP3 Player Questions & Answers
My sandisk SDMX512r freezes at
if u can somehow find it on ur computer: delete all files and folders (including hidden ones),
and do a full format (right click on drive->Format...).
this worked for me.
WILL NOT PLAY FILES IN
Hi tantoy,
I see that you mentioned your MP3 player does not play the files in Proper sequence.
Have you checked maybe it is just in shuffle, because that can be the only reason why the audio file plays randomly instead of in sequence.
I hope this will clear things out.
Have a nice day,
mvincentc
What should be a simple project has me
I found a user manual for this player on the SanDisk forums. You can read the full manual here:
http://kb.sandisk.com/app/answers/detail/a_id/836/kw/dap/r_id/101834
This player does not support playlists, so if you want to play the albums separately, you will have to organize them into folders. So, make one folder for each album and title them appropriately, then move the folders over to the device, and each album will be in its own folder under ROOT.
WHEN I TRY TURNIN IT ON IT JUST STAYS ON THE
Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Power cycle the device.
The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the player to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Unplug the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
