20 Most Recent
Air Conditioning and Heat for Nissan Pulsar Questions & Answers
Cigarette lighter fuse location
12V accessory fuse. if thats good remove the jack and unplug the wires and check for voltage at the wiring harness with a multimeter. if thats good 12-14.5v then check for continuity between the dot in the center of the lighter jack and the middle peg on the back, and the sleeve of the lighter jack and the peg on the side of the jack. make sure the connection is tight between the harness and the jack and reinstall. if it still doesnt work then replace the jack
Fan only works on 4 in nissan pulsar 2005
replace the blower motor resistor! it is a cheap and simple job but if you are not mech inclined your local shop should do it for the price of the part and one hour labor
2001 Nissan Pulsar Q 4door
hi under the hood behind the battery you will see a fuse box i have a feeling you will need to change th air cond relay .the fuse box cover will have a white diagram showing what relay is for the air cond
hope this helps :)
Tappet clearance intake exhaust valve
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj5xrGigOKBAxUdgP0HHQ9gCWIQrAIoAXoECCQQAg&url=https%3A%2F%2Fwww.fixya.com%2Fcars%2Ft29759728-1991nissan_civilian_3_5lt_please_tell&usg=AOvVaw3L1RXEvVBAFwp8YjNQOz34&opi=89978449
My 2000 maxima keyless entry is not working.
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals free
2005 nissan air condition noise clicking inside car
Maybe something hitting the fan blades in the blower? There isn't much inside the car that's specific to the A/C- evaporator, maybe an expansion valve, and some hoses. Most everything else is in the engine compartment. The blower, dampers, and controls may have a problem, but it probably wouldn't be limited to just the A/C
My ac fuses always over heating when the ac is on
If you're saying that you keep blowing the AC fuse when it's running, then you have a problem. The fuse is there to protect the system from an electrical problem. Burning a fuse element means the AC is drawing too much current. Probably a short somewhere.
NEVER replace a fuse with a higher rated fuse- use only the Amperage rating suggested for that circuit.
