20 Most Recent Sceptre X505BV-FMDR 50" LED TV 1920x1080, 60 Hz, HDTV Questions & Answers
2answers
How do i fix a sound, but no picture led tv?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
8/8/2016 10:58:24 PM • Sceptre... • Answered on Aug 08, 2016
Why does a scepter 50" tv go black no sound no nothing
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
12/8/2015 9:10:38 AM • Sceptre... • Answered on Dec 08, 2015
Lcd tv has sound no picture
Hi Chad, Since you are getting the sound, the main board seems ok. Please show a flashlight on the screen, you should be able to see the picture there. If it is so, the backlights in your set are not working. Most LED TVs have LED driver circuit on the power board now days. Here a word of caution, there are two reasons for failed backlights. First the LED driving circuit and second the backlight itself. Which one has in your case, let some TV Tech decide it. In both the conditions your TV should be repairable. Good luck
12/3/2015 11:17:50 PM • Sceptre... • Answered on Dec 03, 2015
I need to know how to program the remote for a brand new 50 scepter 50" tv. I do not have the universal remote control code. Richard
You should have a brand remote as part of your new TV it comes as a package, see your dealer.
12/27/2014 6:17:13 AM • Sceptre... • Answered on Dec 27, 2014
2answers
I have a DVD that is stuck in the player, the eject button does not release it. Help!
You'll have to take the cover off. This only consists of a few screws to remove, and lifting off the cover. When you have the cover off, try turning any white gears (carefully) to open the drawer. Some tray mechanisms have bad design. They refuse to open after a few months. This is in the design of the plastic parts and mechanisms of the cd drawer. Flawed design.
12/17/2022 2:56:15 AM • Sceptre... • Answered on Dec 17, 2022
How to connect laptop to Sceptre TV
HDMI Connection
  1. Connect one end of the HDMI cable to the laptop VGA port.
  2. Connect the other end of the HDMI cable to one of the HDMI connections on the rear of the TV.
  3. Connect a separate audio cable between the headphone or speaker output on the laptop and the audio in connector on the TV.
9/13/2022 3:39:27 PM • Sceptre... • Answered on Sep 13, 2022
Sceptre panel replacement
Your panel is defective, it was damaged from handling.
7/7/2022 10:05:18 PM • Sceptre... • Answered on Jul 07, 2022
My sceptre remote wont turn tv on or off?
Reset the remote by removal and reinstallation of the batteries. Make sure the batteries are good. Follow the setup guide for the remote. Here is a YouTube on how to trun the TV on/off without a remote. https://www.youtube.com/watch?v=SBN47kfPkm0
4/18/2022 12:49:20 AM • Sceptre... • Answered on Apr 18, 2022
How do I get the lock off my Sceptre TV?
I would use the password and adjust the settings. https://www.manualslib.com/manual/516013/Sceptre-24-Lcd-Led-Hdtv.html?page=32
2/17/2022 8:22:31 PM • Sceptre... • Answered on Feb 17, 2022
My Sceptre TV, Version # UXTV58FE has a black screen. Tried all reset hacks, no luck.
Changing the main won't help, it's not what's wrong, you have bad LED backlights and in all honesty it's going to make more sense to buy a new TV but this time buy a name brand
11/16/2021 9:24:11 PM • Sceptre... • Answered on Nov 16, 2021
Sceptre hktv83ac black screen no image
A lot of people miss understand how the backlight circuit in the power supply works, you will get voltage testing to ground as its the B- side that's switched, the chassis ground and backlight B- are not connected. If you tested each LED strip and they're all good there has to be something else going on other than the typical backlight issue we see on so many LED sets.. I'm not an authorized service center for this brand TV so I don't have a service manual, if this set has separate power board and main test the bl_on pin on the power supply, you should have around 3.5 volts there, that's what tells the back light section of the power supply to turn on.If you don't then it's a bad main board
8/12/2021 7:26:33 PM • Sceptre... • Answered on Aug 12, 2021
Sceptre X505BV-FMDR 50" LED TV 1920x1080, 60 Hz, HDTV Logo
11 questions posted
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Televison & Video
Most Popular Question
fix sound but no picture led tv
  • Televison & Video
