20 Most Recent TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim Questions & Answers
How do I connect to a sound bar with optical connection only
if your tv has an optical port, then just connect the two
10/21/2015 4:27:24 AM • TCL 48FS4610 48... • Answered on Oct 21, 2015
TCL 48" POWERS OFF WHEN RECIEVES SIGNAL
lok to see if there is a firmware update. if not... it might need repaired
2/19/2015 9:12:10 PM • TCL 48FS4610 48... • Answered on Feb 19, 2015
TCL 48FS4610 manual?
http://www.tclusa.com/downloads/zTCL_product_downloads/48_48fs4610r/TCL-Roku_User_Guide_082014.pdf
11/20/2014 11:51:28 PM • TCL 48FS4610 48... • Answered on Nov 20, 2014
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
9/9/2014 1:26:32 PM • TCL 48FS4610 48... • Answered on Sep 09, 2014
Tcl l40f10f
try update your TCL TV firmware by current update version file from USB stick https://electronics-tricks.blogspot.com
1/3/2020 10:58:48 PM • TCL Televison &... • Answered on Jan 03, 2020
0answers
L24v10f tcl
Replace the power supply.
6/24/2014 7:19:30 AM • TCL Televison &... • Answered on Jun 24, 2014
0answers
0answers
0answers
Tcl tv repair
It sounds that the main system control memory IC is faulty. Replace it and check. This is a very cheap to buy IC. Eventhough its cost and size is small, the function of it when the set is switched ON, is great. It is a very small IC, having only 8 solder terminals. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
10/12/2013 2:38:16 PM • TCL Televison &... • Answered on Oct 12, 2013
Tcl l32m19 tv wont turn on woke up the other day and the light on the front was not on
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
6/27/2012 12:24:31 AM • TCL Televison &... • Answered on Jun 27, 2012
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 6 hours ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 7 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 8 hours ago
TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim Logo
4 questions posted
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
connect sound bar optical connection
  • Televison & Video
