20 Most Recent Samsung Galaxy Tab S 10.5" Tablet - 16GB, WiFi, Titanium Bronze Questions & Answers
Replaced battery per instructional video and unit will not charge on factory charging cable.
if the device has not had charge in the battery you need to plug it in when red light goes off take charger out fot 3 secs.place back in and do it again in 15+minutes it WILL come on
1/15/2016 6:12:47 PM • Samsung Galaxy... • Answered on Jan 15, 2016
Picture appears, but why does it disappear before I can type in the password?
restart your tab in safe mode.now try your picture if it works then some of your installed app malfunctioning. delete all apps which are not come with your tab. use antivirus and install your desired app again for safe mode try u tube
11/11/2015 10:56:12 AM • Samsung Galaxy... • Answered on Nov 11, 2015
How to install a free flash player
go to adobe.com. click on flash player. download.
5/17/2015 4:19:12 AM • Samsung Galaxy... • Answered on May 17, 2015
Tactile screen does not respond. Why can't I open or close the tablet?
Probably a plug has come off inside... Time for a repair.
4/11/2015 9:07:00 PM • Samsung Galaxy... • Answered on Apr 11, 2015
Cant load my Facebook acc Inf from Apple I6 to my new Galaxy Tablet
Take it to the geniuses... (Apple) or any other tech support that you have with the new unit. Those guys love this type of problem!
4/5/2015 3:02:24 AM • Samsung Galaxy... • Answered on Apr 05, 2015
Why does my new Samsung 10.5 tablet take so long to charge.If you
My first question would be, do you have the factory charger? If not is your ac adapter the right volts and mah? If not you may be experiencing a " trickle charge. " This is where the device is charging but only at a trickle like speed. This happens often with Apple products, when they update all your previous charging cords are useless. Try using a new updated usb charging cord too.
3/5/2015 8:04:44 AM • Samsung Galaxy... • Answered on Mar 05, 2015
How do i upgrade the android on my galaxy tab s 10.5
You should receive updates automatically If you go into settings on the top click on General then scroll down to the bottom of the left hand column then click about device then on the right at the top is software update click that it will show when it was last updated under that is Auto update make sure you have that checked then you will always have the latest updates. if you go back to about device you can then see model number, android version and other details. I have android version 4.4.2 at the moment everyone gets the latest updates at different times you just need some patience. Hope this helps
2/15/2015 8:34:08 PM • Samsung Galaxy... • Answered on Feb 15, 2015
How can i open a finger print password without its option is shown.? there is only one option of alternative password which i was forget?
there is a small reset hole in the edge use paper clip to hold for 5 seconds see if fingerprint option reappears . post picture of opening screen , and use edge of piece paper to clean debri around print sensor button.
1/17/2015 6:34:02 AM • Samsung Galaxy... • Answered on Jan 17, 2015
I cannot access the Internet. It says i am connected, and comes up with a sign in notification. When i select the notification, it opens the browser and loads a completely blank page. This network doe
REGARDLESS of what the initial notice says . open the drop down menu by swiping from the top notice line downward . tap the wifi icon and it will turn off. then turn it back on and tape the gear icon that will open settings , tap the wifi line to open the wifi settings. you should see your network there and be able to sign on. you should start with a blank browser page just type in a website or topic. it should go to the site . also try installing firefox from the store and then use the desktop icon to open the browser. if you still have problems comeback and describe. I have 3 galaxy products Tab 4 ", Tab S 8.4" and note 3 smartphone all using kit kat. so i should be able to walk you through this one
1/17/2015 5:32:05 AM • Samsung Galaxy... • Answered on Jan 17, 2015
How do I get the back botton and homee button to light up on the galaxy 10.5 tab S?
You just touch them. Slide your finger either side of the home button ,the home button doesn't light up at all.
1/2/2015 11:27:51 PM • Samsung Galaxy... • Answered on Jan 02, 2015
I make finger password for high security on my galaxy tab s.my now the finger print option disappear and alternative password is required but my tab does not open through it please help me .?
I don't think you will get a reply as that is the type of question that would be asked by someone that isn't the genuine owner. Why don't you call Samsung if you registered your machine when you got it.
1/2/2015 11:22:28 PM • Samsung Galaxy... • Answered on Jan 02, 2015
How do I get out of the demo mode of the Samsung S 10.5 Tablet?
  1. Power on your tablet.
  2. On the home screen, tap the App button.
  3. Tap the Screensaver app.
  4. Tap Enable Screensaver to turn the screensaver mode on or off.
  5. You want to turn off the screensaver!
12/29/2014 2:57:58 PM • Samsung Galaxy... • Answered on Dec 29, 2014
I need a manual for the samsung galaxy tab s tablet 10.5
try download to other computer and then print it out?
12/20/2014 12:01:17 AM • Samsung Galaxy... • Answered on Dec 20, 2014
Samsung 500T Tablet. How to hard Reset please?
Question edited for clarity. Question moved to Samsung Tablet. https://www.google.com/search?q=Samsung+500T+hard+reset Standard Android Reset
9/15/2023 1:59:05 AM • Samsung Tab... • Answered on Sep 15, 2023
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary. I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started. If that doesn't work, then you can perform a factory reset as described by Samsung here: https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset. Please let me know if this helped you or not.
10/17/2021 6:32:52 PM • Samsung Tab... • Answered on Oct 17, 2021
2answers
I need to obtain a user manual for my husband's Samsung Tablet A8 (he is 82 an needs explicit instructions)
try going google and typing in ---user manual for samsung a8 tablet-- if there is a manual available it will be in pdf version for download
2/1/2018 2:53:47 PM • Samsung Tab... • Answered on Feb 01, 2018
tip
How to make my tablet run faster
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authority.
tablet running really slow Google Search
Samsung Galaxy Tab S 10.5" Tablet - 16GB, WiFi, Titanium Bronze Logo
Popular Tags
17 questions posted
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Tab Samsung
  • Tab Samsung
Most Popular Question
switch screen but closes before type in
  • Tablets & eReaders
